查看: 104|回复: 0
2005 9200 instrument panel malfunction
 楼主| 发表于 2019-1-28 16:21:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2005 International 9200 with a Cummins ISM engine. The engine runs fine but the truck has developed an instrument panel problem. The water temp, oil pressure warning lights flash, the tachometer and speedometer, the voltmeter, oil pressure gauge and water temperature gauge, each pin to the right side of each gauge. I have checked the connections on the panels, cleaned the cab grounds both inside the cab and on the firewall and checked the breaker for the instrument panel. (interestingly enough, the first time I pulled the breaker to check it and then re installed, all the gauges worked fine for another day and a half.) \n\nI have spoken to the dealer and he offered up that I had a data link issue, which provided no resolution to my problem.One other thing, all lights and gauges respond normally upon start up, but it only takes about 5 seconds to fail after that.I certainly would be interested in hearing how others might have resolved this same issue or from anyone that could offer up some further insight.\n\nThanks!","pics":"[]","canComment":true}
GMT+8, 2026-2-4 12:14 , Processed in 0.054944 second(s), 23 queries .
