查看: 69|回复: 0
2019 Freightliner P4 Cascadia 126
 楼主| 发表于 2020-10-10 08:12:03 来自手机 | 显示全部楼层 |阅读模式
VIN: 3AKJHHDR9KSHU6775
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=233a69071750fd9a780&token=8bfcbb8c6311ddc47cbc056ff996b110
mileageV2: 225607
horsePowerV2: 400
engineManufacturerV2: Detroit
transmissionV2: Detroit
transmissionTypeV2: Auto
suspensionV2: Airliner
colorV2: Purple
tiresV2: Dual
wheelbaseV2: 227
zipcodeV2: 65803
cityV2: Springfield
stateV2: MO
condV2: Used
makemodelV2: Freightliner P4 Cascadia 126
phonenoV2: 5623747861
priceV2: 110750
stocknoV2: 690921
latitudeV2: 37.19
longitudeV2: -93.28
modelyearV2: 2019
fuelTypeV2: Diesel
LucrativId: 3670520
LocationId: 2974840
{"text":"2019 P4 Cascadia 126, Powered by a Detroit DD15 and a Detroit DT12-DA-1750 LB/FT @ 975 RPM direct drive transmission with 2.28 ratio for the best fuel economy! 227 Wheel base saves you on weight and makes it easy to maneuver in those tight loading lots. 12,500 front with 40k rears, WABCO ABS system with Hill start aid, Fontain 12.0 Air slide 1/5th wheel, 2-100 gallon fuel tanks, LED fog lights, Webasco air top heater, Detroit assurance lane departure, Detroit assurance collision warning with active brake assist, Headlights on with wipers, Includes the remainder of the 4 year 600k warranty, Virtual technician, Thermoking APU, Dorm style fridge, All aluminum wheels & 10 new virgin tires. Inspected, serviced, Engine Dyno and fully detailed. Call today for more information!","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 16:56 , Processed in 1.452395 second(s), 25 queries .
