查看: 287|回复: 12
what's wrong with rand mcnally
 楼主| 发表于 2020-10-10 06:36:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"can anyone tell me why it seems rand mcnally truck gps only last about 1year? I have had 3 different one's.. all 3 lasted about a year.. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-10 13:37:02 来自手机 | 显示全部楼层
936953 发表于 2020-10-10 00:19:30 I’m no year 7 with my my 750 about 800,000 miles. It’s still kickin but barely.
","text":"Garmin is better ","replyToPid":401966}
发表于 2020-10-10 08:12:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I sent my TND 70. Back to them. Cost 100 bucks but they fixed it. It’s usually the battery or charging ports ","replyToPid":0}
发表于 2020-10-10 08:36:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Wow.  I’ve owned 3 in the past 10 years.  Had no problems with the first 2 but this new one(Tablet 85) I bought in January has been garbage... stops charging while on the dock and screen has developed some white spots."}
发表于 2020-10-10 08:19:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m no year 7 with my my 750 about 800,000 miles. It’s still kickin but barely.","replyToPid":0}
发表于 2020-11-3 08:31:18 来自手机 | 显示全部楼层
162871 发表于 2020-10-10 15:31:23 plug your USB c directly into the side of the unit and bypass the magnetic dock
","text":"It’s micro USB, not USB-c, but yeah I’ve been doing that since the first time the problem started.  I use a magnetic cable so I still get the same quick remove functionality like the dock. ","replyToPid":402053}
发表于 2020-10-12 08:25:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did my research and looked at reviews of both Rand McNally and Garmin and decided to go Garmin. 6 years and going with the Garmin. The Rand didn't get very good reviews back then.","replyToPid":0}
发表于 2020-10-11 11:15:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Planned obsolescence.   They don't make any money at $400-500 a pop if you don't buy one every other year...","replyToPid":0}
发表于 2020-10-10 23:31:23 来自手机 | 显示全部楼层
649885 发表于 2020-10-10 00:36:51 Wow.  I’ve owned 3 in the past 10 years.  Had no problems with the first 2 but this new one(Tablet 85) I bought in January has been garbage... stops charging while on the dock and screen has developed some white spots.
","text":"plug your USB c directly into the side of the unit and bypass the magnetic dock","replyToPid":401977}
发表于 2020-10-10 23:11:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"mine is 4.5 years old, it's my 4th one. each one lasted about 4 years. but, I found out I killed one by not using the rand McNally charger, I didn't know it required at least a 2.4 volt.","replyToPid":0}
发表于 2020-10-10 19:22:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t know don’t have GPS ","replyToPid":0}
发表于 2020-10-10 08:14:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"My husband has owner 2 over 9 years & both are still working fine. His brother has one too for about 5 years & still using it. Not sure why yours didn’t last. Sorry. ","replyToPid":0}
 楼主| 发表于 2020-10-10 22:04:48 来自手机 | 显示全部楼层
630463 发表于 2020-10-10 00:12:14 I sent my TND 70. Back to them. Cost 100 bucks but they fixed it. It’s usually the battery or charging ports
","text":"mine is saying gps signal not found.. it's been like that for 3 days and 1500 miles..","replyToPid":401960}
GMT+8, 2026-2-9 16:10 , Processed in 0.057336 second(s), 24 queries .
