查看: 624|回复: 11
What does it mean? ..if CA, must pin be in 5th hole, at least 5th hole or more, or 5th hole and less, what about weight?
 楼主| 发表于 2020-10-9 23:32:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true,"externalShare":false}
发表于 2020-10-10 07:00:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"just don't go to that communist place\nwe don't","replyToPid":0}
回复 支持 12 反对 4
发表于 2020-10-10 09:44:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think it’s weird because it’s slow speeds for wind. Isn’t a tandem set back better in the wind? Why do they want me to sail down the mountain? ","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-10-10 09:45:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"None of us diesel folk will be there much longer anyways. They are banning diesel vehicles. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-10-10 08:54:14 来自手机 | 显示全部楼层
438324 发表于 2020-10-09 23:00:52 just don't go to that communist place\nwe don't
","text":"Don't worry I'm sure we're on the guest list to watch Cali split away from the US and become an island.","replyToPid":401944}
禁止发言
发表于 2020-10-10 07:15:28 来自手机 | 显示全部楼层
发表于 2020-10-10 13:40:18 来自手机 | 显示全部楼层
678033 发表于 2020-10-10 01:44:52 I think it’s weird because it’s slow speeds for wind. Isn’t a tandem set back better in the wind? Why do they want me to sail down the mountain?
","text":"Nancy pelouse will explain it tomorrow.🙄😅😀😄😁😃😀😂😂😁😃😀","replyToPid":401984}
发表于 2020-10-10 10:38:30 来自手机 | 显示全部楼层
678033 发表于 2020-10-10 01:45:26 None of us diesel folk will be there much longer anyways. They are banning diesel vehicles.
","text":"It would take a lot of years of diesel trucks driving to equal the amount of emissions to the fires from just the past couple years ....! \n","replyToPid":401985}
发表于 2020-10-13 10:12:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"In Cali the maximum length of the tandems from the kingpin is 40 ft. the reason is maneuverability. Axle weight is 34000, if the shipper puts too much on the back of the trailer then they must move it or take it off.","replyToPid":0}
发表于 2020-10-10 12:07:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Axles must be 34,000 pounds or less, so it is a loaders art to place the freight so the axles scale legal.  \n\nCalif. bridge law is 40 feet for safely maneuvering in city traffic and mountain roads. 40  feet maximum. \n\nThen tell the loaders to re-work the load.","replyToPid":0}
发表于 2020-10-12 08:33:56 来自手机 | 显示全部楼层
","text":"the 55 law was put in place in the guise of safety but there is the idea that it reduces emissions also. wasn't so much for wind but to reduce the stopping distances needed.","replyToPid":401984}
发表于 2020-10-11 22:39:18 来自手机 | 显示全部楼层
","text":"Tandem position is not going to help you in the wind.","replyToPid":401984}
GMT+8, 2026-4-18 01:28 , Processed in 0.136249 second(s), 24 queries .
