查看: 140|回复: 0
2016 UTILITY 3000R
 楼主| 发表于 2020-10-8 08:12:10 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
VIN: 1UYVS2531GM410423
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=436fd9f3175058d09aa&token=3eaa3ca1be9f27591b9f6363ed9c098f
suspensionV2: Hendrickson
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
categoryV2: Reefer Trailers
zipcodeV2: 84104
cityV2: Salt Lake City
stateV2: UT
condV2: Used
makemodelV2: UTILITY 3000R
phonenoV2: 5623747861
priceV2: 33500
stocknoV2: 160622
latitudeV2: 40.74
longitudeV2: -111.98
modelyearV2: 2016
compartmentsV2:
includeForkliftV2: -
LucrativId: 3632221
LocationId: 2974833
{"text":"2016 Utility 3000R with Carrier X4 7500 reefer 10,xxxhrs, Disc Brakes, Air Ride, Air Slide, Right Weigh Load Scale Gauge, Fuel Saving Skirts, Bendix Eversure 3030 Air Brake System, TABS-6 Advanced ABS with Roll Stability, Hendrickson Vented Axles, Meritor PSI Tire Inflation with Thermalert, Right Weigh Load Scale, Hendrickson ULTRAA-K Slider System with Zero Maintenance Dampening, Bendix Disc Brakes, Stainless Steel Corner Posts, UTM Barrier Design Double Swing Stianless Steel Diamond Pattern Rear Doors, Anti-Theft Tamper Proof Hardward, Recessed swing door holdback, Heavy Duty Extru Alum Wedge Type Rear Thershold w/4 Dock Board Guide Plates, Veritex Wall Lining, Grote Supernova and Trucklite series LED lights, Side Skirts, and more...","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 17:00 , Processed in 0.052880 second(s), 25 queries .
