查看: 250|回复: 15
Route Choice
 楼主| 发表于 2020-10-7 09:55:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi I'm going to Groveport Ohio from Miami. should I take i75 thorough Georgia Kentucky (80 miles longer) OR i95/i77 Through North Carolina and West Virginia??? It looks more Hilly but is 80 mile shorter. please suggest","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":3200.0,\"name\":\"\",\"url\":\"\",\"width\":1440.0}]","canComment":true,"externalShare":false}
发表于 2020-10-7 10:45:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Avoid WV like the plague ","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-10-7 10:21:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I myself would go 75","replyToPid":0}
发表于 2020-10-7 10:43:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"To me depends on your load. Heavy, do the 75 save on fuel. Also them hills aren't that fun in the dark. I like to see what's ahead when doing mountain runs.","replyToPid":0}
发表于 2020-10-7 10:21:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I95 b better ","replyToPid":0}
发表于 2020-10-8 04:35:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"i77 is $80 tolls","replyToPid":0}
发表于 2020-10-7 13:11:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"95 to 77 not to bad. General rule is to stay around 40 mile OOR. 75 has some hills through Tennessee anyway, not to bad if your light in the box though. You'll get a few hill in Virginia running 95, but your not on it long 77 a pretty good road. will about $40.00 to go through there. I personally would run 95 to 77 but you'll get there either way. hope this helps","replyToPid":0}
发表于 2020-10-7 12:25:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"   I always choose I 75  ","replyToPid":0}
发表于 2020-10-7 11:07:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I75","replyToPid":0}
发表于 2020-10-7 11:04:31 来自手机 | 显示全部楼层
936953 发表于 2020-10-07 02:45:59 Avoid WV like the plague
","text":"WV ain't no fun","replyToPid":401486}
发表于 2020-10-7 11:02:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would take 75 better ","replyToPid":0}
发表于 2020-10-7 10:28:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I77 is nothing but hills ","replyToPid":0}
 楼主| 发表于 2020-10-7 10:51:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you all for your suggestions.  I'm taking i75 🙏❤","replyToPid":0}
GMT+8, 2026-2-12 03:59 , Processed in 0.136198 second(s), 24 queries .
