查看: 172|回复: 7
low - bridge clearense
 楼主| 发表于 2020-10-7 05:33:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"this app has low bridge clearence","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-7 05:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Would you believe it says the clearance on the bridge too lol oh and it’s spelled with a C not S ","replyToPid":0}
发表于 2020-10-7 07:08:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t believe everything you read on your phone.","replyToPid":0}
发表于 2020-10-7 10:52:20 来自手机 | 显示全部楼层
936953 发表于 2020-10-06 23:08:44 Don’t believe everything you read on your phone.
","text":"Don't believe what the vendor says either on your trailer height or what GPS says. Almost can opened a curtain side trailer going through Chicago. I was leary and went slow and when it started to hit I dropped the bags and backed up. Did a u turn across the median right behind a cop. Kept on rolling.","replyToPid":401375}
发表于 2020-10-7 10:53:35 来自手机 | 显示全部楼层
674413 发表于 2020-10-06 21:59:42 Would you believe it says the clearance on the bridge too lol oh and it’s spelled with a C not S
","text":"Not all. I've seen several that aren't marked and I thought it was law that they are supposed to be.","replyToPid":401367}
发表于 2020-10-7 20:53:49 来自手机 | 显示全部楼层
764614 发表于 2020-10-07 02:53:35 Not all. I've seen several that aren't marked and I thought it was law that they are supposed to be.
","text":"Federal mandate anything 14’6” and below has to be posted ","replyToPid":401490}
发表于 2020-10-8 11:18:15 来自手机 | 显示全部楼层
936953 发表于 2020-10-07 12:53:49 Federal mandate anything 14’6” and below has to be posted
","text":"I know and that's what I don't get. No one must be turning them in. But I guess if you do damage to your equipment because it's not marked there could be a huge lawsuit.","replyToPid":401539}
发表于 2020-10-8 12:46:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"BS. No federal mandate dictates posting requirements for minimal bridge clearance. Those minimal posted clearances differ state to state.","replyToPid":0}
GMT+8, 2026-4-18 01:57 , Processed in 0.109554 second(s), 24 queries .
