查看: 138|回复: 4
Ole CB
 楼主| 发表于 2020-10-7 03:15:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Roger, good buddy. \n     Ole CB rides shotgun with me everywhere I go. He’s kept me from piling up, found me a paycheck, rerouted me, kept me awake, prevented costly repairs and left lane certifications, educated me, kept me in line and saved me time. He’s even worked as a real time backup camera. \n    It’s a real shame he’s not standard equipment in every truck on the road. \n     You got the Silver Bullet on this side, readin’ the mail, waving’ a hand and steppin’ out. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-7 03:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"👍👍👍💯","replyToPid":0}
发表于 2020-10-12 07:10:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"What type of radio setup are you currently running? ","replyToPid":0}
 楼主| 发表于 2020-10-12 07:19:41 来自手机 | 显示全部楼层
1022175 发表于 2020-10-11 23:10:11 What type of radio setup are you currently running?
","text":"I am not bringing much heat, just a cobra 29 LX that’s been tuned up a little. Wilson T2000 Trucker antennas. Duel, so that I can hear better. I would be better off on output with a single.","replyToPid":402238}
发表于 2020-10-12 21:20:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like you have a good setup, and you are correct on the twins, they do give you a little more receive but the output loss isn’t worth the trade since the receive boost is extremely slight but most like the way it looks so if that’s the case and your standing wave ratio is 1.5 or less then you are golden. ","replyToPid":0}
GMT+8, 2026-2-9 22:40 , Processed in 0.071446 second(s), 24 queries .
