查看: 95|回复: 6
97 International vent air
 楼主| 发表于 2020-10-4 05:27:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Wondering if anyone knows if it's normal for dash and defrost air flow to be low in a 97 international. I replaced one blower motor that was bad, but doesn't seem like it blows outta the vents very good. Didn't know if that's how they are or if I need to end up doing more investigating.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-4 05:39:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the filter....","replyToPid":0}
发表于 2020-10-4 11:03:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"make sure that it doesn't have 2 filters some of the older models had 2 filters","replyToPid":400904}
 楼主| 发表于 2020-10-4 08:48:12 来自手机 | 显示全部楼层
766797 发表于 2020-10-03 23:19:11 ..maybe the doors for circulation or fresh got stuck close???👍🇺🇲
","text":"I'll have to check the fresh intake. Inside cab intake works. Switches from defrost to cab, both little air on high.","replyToPid":400913}
发表于 2020-10-4 11:02:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"could be an actuator....","replyToPid":0}
 楼主| 发表于 2020-10-4 06:25:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"brand new","replyToPid":400901}
 楼主| 发表于 2020-10-4 08:47:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll have to check the fresh intake. Inside cab intake works. Switches from defrost to cab, both little air on high.","replyToPid":0}
GMT+8, 2026-2-10 00:13 , Processed in 0.064880 second(s), 24 queries .
