查看: 407|回复: 11
New Hours of Service has almost indefinite 14 hour window.
 楼主| 发表于 2020-10-3 03:35:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"So long as you take at least 2 hours of off duty, your clock is paused.  Sit in a dock for 5 hours, day gets extended for 5 hours making your day 19 hours instead of 14.  You can do this again, another 4 hours and your day gets extended to 23 hours, lol.  I just had 4 hours off and indeed my 14 paused.  Companies can now have drivers “technically” stay up almost indefinitely if need be, lol.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-10-3 11:43:32 来自手机 | 显示全部楼层
14899 发表于 2020-10-02 20:48:17 paper logs....is the way to go.... nothin will change my opinion on this.... just because some can't add or do math and figure a trip should not be the reason they tell us when we have to sleep or sit around get tired and then have to drive......we actually worked for our money back in the day
","text":"I agree with you, hate elogs myself. Recently did a post trip, then had a call from the wife and forgot to go off duty. Four hours later the thing is beeping at me that I am running out of on duty hours. It was my mistake, but no way to go back and fix it.","replyToPid":400668}
发表于 2020-10-3 04:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"paper logs....is the way to go.... nothin will change my opinion on this.... just because some can't add or do math and figure a trip should not be the reason they tell us when we have to sleep or sit around get tired and then have to drive......we actually worked for our money back in the day","replyToPid":0}
发表于 2020-10-5 09:52:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"messn around is dead on!!!!  Been out here 42 years. The more the government intervenes, the worse it gets!","replyToPid":0}
发表于 2020-10-3 21:19:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm not feeling comfortable with how the logs might be working and will probably try when I can to stick with 10 hour breaks, asking for extended pta for 8 in the sleeper. I'm not feeling competitive right now. I'd rather focus on my weight loss and maybe learn diesel mechanics online or what have you. if my company needs a rush on something they know where to find me and can ask for a push. otherwise this is me season.","replyToPid":0}
发表于 2020-10-3 04:54:59 来自手机 | 显示全部楼层
766797 发表于 2020-10-02 20:53:31 👍👍👍🇺🇲🇺🇲🇺🇲📒✏💲💲💰💰💸😄
","text":"yes sir...🇺🇸🇺🇸🇺🇸.. that was when we were allowed to do our job and deliver the mail...metaphorically speaking","replyToPid":400670}
发表于 2020-10-3 05:24:16 来自手机 | 显示全部楼层
no after 4 you have to take 6.....
{"replyToPid":400650,"replyTo":"
766797 发表于 2020-10-02 19:54:44 no after 4 you have to take 6.....
","text":"you have to take a 7hr no mater what example \n3 & 7\n4 & still 7 not 6\n6:59 & 7.         or  2 & 8\nhttps://youtu.be/LxNFKVnaSW0"}
 楼主| 发表于 2020-10-3 09:24:50 来自手机 | 显示全部楼层
","text":"I run elogs and I’ve been up since 0530 and my logs show that I still have 5 hours in my logs and it’s 8pm...  I only have a 5 and half hour off duty time and no sleeper time.... so unless my elogs are messed up and no where does it say that on the website.  I can post a picture.  "}
发表于 2020-10-3 21:21:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"if I'm using up my 70 I've done my work for my company. I'm not being lazy. how that's managed is up to me. they can't have more than 70 and it's better to be balanced on your hours so they can rely on you every day.","replyToPid":0}
发表于 2020-10-4 04:11:44 来自手机 | 显示全部楼层
925557 发表于 2020-10-03 03:43:32 I agree with you, hate elogs myself. Recently did a post trip, then had a call from the wife and forgot to go off duty. Four hours later the thing is beeping at me that I am running out of on duty hours. It was my mistake, but no way to go back and fix it.
","text":"👍","replyToPid":400751}
GMT+8, 2026-4-18 07:13 , Processed in 0.070273 second(s), 24 queries .
