查看: 212|回复: 6
Hey guys. What should I do if the LED bar part stops working in this headlight? I couldn’t find the actual bulb for it.
 楼主| 发表于 2020-9-27 23:57:47 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":640.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true,"externalShare":false}
发表于 2020-9-28 20:33:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have to replace the entire assembly.","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-9-29 05:06:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Assemblies like that are usually sealed, so to get inside really isn't an option. There cool looking, but not worth it when you have to replace the whole thing when one bar burns out.","replyToPid":0}
 楼主| 发表于 2020-9-29 01:24:51 来自手机 | 显示全部楼层
936953 发表于 2020-09-28 12:33:38 Have to replace the entire assembly.
","text":"Exactly what I was afraid of. But Thank you for the Heads up. ","replyToPid":399875}
发表于 2020-9-29 05:07:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"You could also contact the company that makes them and see if it is changeable. Never know till ya ask.","replyToPid":0}
 楼主| 发表于 2020-9-29 10:06:03 来自手机 | 显示全部楼层
764614 发表于 2020-09-28 21:06:47 Assemblies like that are usually sealed, so to get inside really isn't an option. There cool looking, but not worth it when you have to replace the whole thing when one bar burns out.
","text":"Yeah you right. I’ve looked up everywhere but it’s not replaceable ","replyToPid":399930}
发表于 2020-9-30 00:03:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"stop buying crap at the truck stop you won't have that problem","replyToPid":0}
GMT+8, 2026-3-22 00:32 , Processed in 0.080185 second(s), 24 queries .
