查看: 214|回复: 6
is freight volume slowing ??!!
 楼主| 发表于 2020-9-26 10:13:06 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-9-26 21:15:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Areas I run pulling reefer are busier than ever with highest rates I’ve ever seen. I’m pulling a Chicago to eastern PA on Tuesday paying $4.28/mile. 1/1.","replyToPid":0}
发表于 2020-9-27 18:37:09 来自手机 | 显示全部楼层
945974 发表于 2020-09-26 13:15:23 Areas I run pulling reefer are busier than ever with highest rates I’ve ever seen. I’m pulling a Chicago to eastern PA on Tuesday paying $4.28/mile. 1/1.
","text":"I'm pulling a dry van from Elwood Illinois to Eastern Pennsylvania for $4.10 😁","replyToPid":399582}
发表于 2020-9-26 10:27:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"volume????","replyToPid":0}
 楼主| 发表于 2020-9-26 10:28:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"did not see much loads past 2 days","replyToPid":0}
发表于 2020-9-26 21:03:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was called back from home a little early but it was a pretty light meat load. I've done different things lately outside the usual food stuff. I wasn't sure if it's because I have my cat with me and that was why since some places won't allow pets. maybe it's slower though. traffic seems heavy. maybe you're in a slow lane of flow.","replyToPid":0}
发表于 2020-9-28 09:53:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe the company you work for is garbage","replyToPid":0}
GMT+8, 2026-2-10 01:49 , Processed in 0.088192 second(s), 24 queries .
