查看: 326|回复: 13
TV install in a truck
 楼主| 发表于 2020-9-25 22:34:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"It's time I add some creature comforts in the truck. I've seen expensive tvs at truck stops. I'm wondering a truck required a special type of tv to deal with all the vibrations and banging around. Also will a 40 inch tv work with a 2000 watt inverter? What's the best way to mount it?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-25 22:54:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, I just wrap my TV, PS4 pro and Xbox in pillows and blankets to absorb the vibrations.  Don’t waste your money on tvs from truckstops.  You can get 4K TVs from Walmart for what they’d gouge you at truckstopd","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-9-25 22:54:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"You won’t regret this decision, it’ll do wonders for your mental health","replyToPid":0}
发表于 2020-9-25 22:54:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use a 24 in TV, got a TV mount from harbor freight for $15. vibration doesn't seem to bother it. I use a 3000 watt inverter,  have fridge, 900w micro and TV all plugged in,  never used all 3 at same time, would think that depending on initial draw from TV would be only concern,  otherwise I think you should be good.","replyToPid":0}
发表于 2020-9-25 22:54:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bought a cheap wall mount from harbor freight. the cabinet behind the passenger seat in a Cascadia is where i mounded it. the side facing the back of truck. I mounted a 32 inch flat screen and had no problems with it. when I drove I would flip the TV sideways on the mount and let the top bunk down to keep the TV from moving outwards. be sure to put some big washers on each side of the bolts. it was a little noisy on bumps with that big of a tv and you could go smaller if you'd like but its possible and easy to install. hope this helps","replyToPid":0}
发表于 2020-9-26 03:14:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Even the $40 100W inverter is enough for my 24in lg tv. and I use my 1000W inverter for my fridge and microwave. I run them all at the same time with no issues.\nthen I just plug my tablet into my tv with a usb c to hdmi cable and use my phone as a hotspot, and bam! Home entertainment center!","replyToPid":0}
发表于 2020-9-26 04:59:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah don’t listen to the clowns who say not to make it home out here.  A lot of people just say they drive and sleep but that’s a really depressing way to live.  You need to have some type of connection to a regular life or you’ll lose your mind.","replyToPid":0}
发表于 2020-9-26 10:56:46 来自手机 | 显示全部楼层
993962 发表于 2020-09-26 01:16:00 Bruhhhhhh I just started playing Death stranding.  This is a very realistic simulation of being a delivery dude during a pandemic lol
","text":"yeah not my cup of tea but looking at the trailer looks pretty interesting","replyToPid":399535}
发表于 2020-9-26 09:16:00 来自手机 | 显示全部楼层
28352 发表于 2020-09-25 22:56:57 I have a playstation 4 and a 32\" inch flat screen draws no more than 220 watts so even a 400 watt inverter at the truck stop is more then enough to run them. Dont get one from the truck stop between the quality of the screen and over pricing your better off spending it on a good quality TV
","text":"Bruhhhhhh I just started playing Death stranding.  This is a very realistic simulation of being a delivery dude during a pandemic lol","replyToPid":399519}
发表于 2020-9-26 06:56:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a playstation 4 and a 32\" inch flat screen draws no more than 220 watts so even a 400 watt inverter at the truck stop is more then enough to run them. Dont get one from the truck stop between the quality of the screen and over pricing your better off spending it on a good quality TV","replyToPid":0}
禁止发言
发表于 2020-9-26 05:29:25 来自手机 | 显示全部楼层
发表于 2020-9-26 05:56:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use a 12 volt 22” nexa with DVD player made into it 140 eBay ","replyToPid":0}
GMT+8, 2026-4-18 12:08 , Processed in 0.928109 second(s), 24 queries .
