查看: 208|回复: 2
battery tender
 楼主| 发表于 2020-9-24 09:01:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Wondering if anyone uses a battery tender. I have a 4 battery setup and I leave my inverter on running my fridge. Sometimes the truck will sit for 3 days before I go out again and I'm not able to get an apu till next year sometime. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-24 11:09:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Battery tender is 1 maybe 2 amps. Not enough to run a fridge. If you’re talking about a solar powered one they’re even lower live .5 amps. Empty the fridge and shut it off.","replyToPid":0}
 楼主| 发表于 2020-9-24 23:53:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not to run the fridge, to keep the batteries charged while the truck sits for a couple of days. I don't take all my food out of the fridge and so there's the draw on the batteries from that. The maintainer I tried got hot and so I'm seeing what else to do or if a maintainer will work.","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.332288 second(s), 24 queries .
