查看: 339|回复: 6
Overweight????
 楼主| 发表于 2020-9-22 10:50:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"My company dispatch told me that NY state has allowed us to run over weight and over hours due to the pandemic. Is this true as of 09/21/2020","videos":"[]","link":"{}","pics":"[]","canComment":false,"externalShare":false}
发表于 2020-9-22 11:02:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"i wouldnt believe it","replyToPid":0}
 楼主| 发表于 2020-9-22 11:05:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounded like BS to me as well. It does seem most scales in NY are closed on trucker path app, or is that just closed right now?","replyToPid":398514}
发表于 2020-9-22 11:18:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s the latest Covid Exemption from FMCSA \n\nhttps://www.fmcsa.dot.gov/emergency/extension-modified-expanded-emergency-declaration-no-2020-002-under-49-cfr-ss-39025","replyToPid":0}
发表于 2020-9-22 11:17:13 来自手机 | 显示全部楼层
986751 发表于 2020-09-22 03:05:00 Sounded like BS to me as well. It does seem most scales in NY are closed on trucker path app, or is that just closed right now?
","text":"NY scales are more of a randomly opened situation. 99% are located in Rest Areas, so almost never opened at night.","replyToPid":398518}
 楼主| 发表于 2020-9-22 11:02:24 来自手机 | 显示全部楼层
766797 发表于 2020-09-22 02:58:15 hour depending on the load i it's \"directly \" contacted to the relief effort \nveight not overweight need to be permitted and comply with all bridges laws....
","text":"Hauling produce, so I’m guessing the HOS part is true of what they said. Overweight might be a fairytale ","replyToPid":398504}
发表于 2020-9-22 13:13:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"cool man, not getting your Information from the governing body, makes you a prime candidate for fake news.\n\nhow about you check with NY DOT?","replyToPid":0}
GMT+8, 2026-4-18 01:03 , Processed in 0.089266 second(s), 24 queries .
