查看: 202|回复: 17
Recap Tire on Drive excel
 楼主| 发表于 2020-9-22 04:49:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"By law, recaps tire we can use for drive excel on trcuk?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-22 08:49:03 来自手机 | 显示全部楼层
984141 发表于 2020-09-21 23:43:37 On the cdl exam you cannot run recapp tires on your steers..how do you have a cdl and not know this !  Only broke a.ss mofo use recapp tires anyways
","text":"i actually cited the exact statute in the FCMSA that states when it is legal to run recaps on steer tires. Please state the statute that says you cannot period, not just claim your CDL test said you cannot. Many very  large fleets run recaps on steer tires on their city trucks, UPS, Fedex, and garbage haulers to name a few. Last I check they are not \"Broke\" city trucks run at a lower average speed and therefore have lower tire temps than OTR trucks do.","replyToPid":398447}
发表于 2020-9-22 06:27:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, recaps anywhere except steer ","replyToPid":0}
发表于 2020-9-22 06:13:14 来自手机 | 显示全部楼层
984141 发表于 2020-09-21 22:01:53 by law, you should learn English
","text":"😂 ","replyToPid":398429}
发表于 2020-9-22 12:21:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂. Stop. 😂 ","replyToPid":398554}
发表于 2020-9-22 11:05:32 来自手机 | 显示全部楼层
{"replyToPid":398444,"replyTo":"
925557 发表于 2020-09-21 23:19:35 FMCSA Title 49, Part 393.75 (e) The answer is yes and no. It all depends on what the load carrying capacity of the tire is. If it equal to or greater than 4,290 pounds, the answer is no you cannot run retreads on steer tires. If it is under you may run retreads on steer axles. I would not run them on OTR trucks due to higher tire temps, but many city fleets do run them.
","text":"."}
发表于 2020-9-22 12:18:09 来自手机 | 显示全部楼层
879242 发表于 2020-09-22 03:55:23 Judgmental are we ?! Gov. Worker ?!
","text":"S hut Up S tupid ","replyToPid":398548}
发表于 2020-9-22 12:22:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Po boy ","replyToPid":0}
发表于 2020-9-22 12:13:41 来自手机 | 显示全部楼层
984141 发表于 2020-09-22 03:16:36 Bridgestone 295/75R22.5\nSteer 5980 lb @ 105 psi; 6175 lb @ 110 psi
","text":"If you read the statute, the weight limit only applies to regrooved tires. There is no load carrying capacity for recaps or retreads. I have not seen regrooved tires in many years.","replyToPid":398534}
发表于 2020-9-22 11:55:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Judgmental are we ?! Gov. Worker ?!","replyToPid":398435}
发表于 2020-9-22 11:54:38 来自手机 | 显示全部楼层
","text":"Arsehole. And I haven’t finished reading ","replyToPid":398429}
发表于 2020-9-22 07:19:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"FMCSA Title 49, Part 393.75 (e) The answer is yes and no. It all depends on what the load carrying capacity of the tire is. If it equal to or greater than 4,290 pounds, the answer is no you cannot run retreads on steer tires. If it is under you may run retreads on steer axles. I would not run them on OTR trucks due to higher tire temps, but many city fleets do run them.","replyToPid":0}
发表于 2020-9-22 09:02:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"FMCSA Title 49, Part 393.75 (d) is the only statute that bans running retreads or recaps on a CMV steer tires, and it only applies to buses. Each individual state might have different regulations, but the FMCSA does not have a total ban on recaps or retreads on steer tires. I have had a class A CDL for 30 years, and was a fleet manager for almost 10 years.","replyToPid":0}
发表于 2020-9-22 09:44:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did mention that I would not run retreads on an OTR CMV because of the higher average speed and higher operating temperature than a city truck. If you do some research you will find it is not illegal in most recaps on steers under most circumstances. It is a common misperception to believe it is never allowed.","replyToPid":0}
发表于 2020-9-22 10:38:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wtf. Huh. 😂 ","replyToPid":0}
GMT+8, 2026-2-10 03:33 , Processed in 0.088167 second(s), 24 queries .
