查看: 317|回复: 9
Truck driver assessment question
 楼主| 发表于 2020-9-20 00:25:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Answer this Based on your Experience as a Truck Driver. Florida assessment test has this question, Apparently what we learnt on the roads as drivers are wrong. So I’m curious to who has more knowledge, The people sitting in the office or the drivers that’s actually on the roads.\nAnswer this to the best of your knowledge\nWould you: \nA: Look ahead for any hazards or dangerous situations to avoid.\nB: Avoid unauthorized persons from entering truck.\nWhich will you choose.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-20 09:40:07 来自手机 | 显示全部楼层
1012870 发表于 2020-09-19 19:16:03 depends on what the question is. If I'm a white male who doesn't lift, is paranoid of being robbed and killed, sitting at a stop light in the middle of the night scared shlt full in my pants, I'd be B.\n\nA if I'm driving like a normal person
","text":"what is bein white got to do with anything","replyToPid":398055}
回复 支持 8 反对 0
发表于 2020-9-20 03:16:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"depends on what the question is. If I'm a white male who doesn't lift, is paranoid of being robbed and killed, sitting at a stop light in the middle of the night scared shlt full in my pants, I'd be B.\n\nA if I'm driving like a normal person"}
回复 支持 2 反对 5
发表于 2020-9-21 01:21:32 来自手机 | 显示全部楼层
","text":"Same old crap! Typical from you.  I had long conversation about your troll of many accounts ","replyToPid":398055}
发表于 2020-9-20 21:27:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Both ","replyToPid":0}
发表于 2020-9-20 02:43:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s both. It’s a trick question both answers are correct ","replyToPid":0}
发表于 2020-9-20 02:09:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"both","replyToPid":0}
 楼主| 发表于 2020-10-4 11:05:00 来自手机 | 显示全部楼层
","text":"What does being white have to do with my question?.. If you can’t answer a simple thread logically you can refrain from making any comments. ","replyToPid":398055}
 楼主| 发表于 2020-10-4 11:06:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea they both are. I was refused the job position because of answers I chose to this assessment, makes no sense you go thru is many schooling and to fail simple things like this. Ridiculous ","replyToPid":398170}
发表于 2020-10-6 23:03:00 来自手机 | 显示全部楼层
557822 发表于 2020-10-04 03:06:47 Yea they both are. I was refused the job position because of answers I chose to this assessment, makes no sense you go thru is many schooling and to fail simple things like this. Ridiculous
","text":"That stinks..sorry.","replyToPid":400957}
GMT+8, 2026-4-18 01:04 , Processed in 0.101328 second(s), 24 queries .
