查看: 73|回复: 2
150 nautical miles to land miles program question
 楼主| 发表于 2020-9-19 05:40:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Wondering the best 150 mile ag exempt  to nautical mile program. Example, type in your location, type in your destination and it would tell you the 150 nautical miles point???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-19 06:37:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I may suggest, take a compass and measure out 150 miles on a map of the United States. Then put the sharp point on your point of origin and draw a full circle. Anything inside of said circle is where you can travel. Good luck","replyToPid":0}
 楼主| 发表于 2020-9-19 08:15:56 来自手机 | 显示全部楼层
874486 发表于 2020-09-18 22:37:30 If I may suggest, take a compass and measure out 150 miles on a map of the United States. Then put the sharp point on your point of origin and draw a full circle. Anything inside of said circle is where you can travel. Good luck
","text":"Thanks for the response ","replyToPid":397921}
GMT+8, 2026-2-12 12:43 , Processed in 0.064282 second(s), 23 queries .
