查看: 867|回复: 20
How high do you idle your truck?
 楼主| 发表于 2020-9-18 05:38:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"I got a 2017 Cascadia Evolution I was told idling is the worst thing you can do to your truck, I can’t afford an apu as of right now maybe later down the road. I was told to use high idle while in sleeper. So how high am I suppose to idle to prevent it from taking a toll on the engine? Thanks! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2020-9-18 06:18:55 来自手机 | 显示全部楼层
禁止发言
发表于 2020-9-18 06:03:58 来自手机 | 显示全部楼层
禁止发言
发表于 2020-9-18 06:18:36 来自手机 | 显示全部楼层
 楼主| 发表于 2020-9-18 06:30:17 来自手机 | 显示全部楼层
147103 发表于 2020-09-17 22:18:55 By idling you will need to regen often
","text":"Yea I know, I just bought the truck and a some what used reefer and paid the insurance people. Don’t want to dip into the maintenance fund to buy an APU I’m on a search for a used or refurbished APU. Been driving since I was 22, just turned 27 been wanting to become an O/O since I started thought a Freightliner would be a good starter truck thanks for the info! ","replyToPid":397817}
 楼主| 发表于 2020-9-18 06:08:59 来自手机 | 显示全部楼层
766797 发表于 2020-09-17 22:04:23 we idle truks from the times trucking get started.. just keep it in optimal temp. and oil pressure  you be ok i running mines at 850...👍🇺🇲
","text":"Thank you ","replyToPid":397804}
 楼主| 发表于 2020-9-18 06:06:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I meant as in RPM wise, like 900 RPM 1,000 RPM? What is the best RPM to idle at, new O/O didn’t really care of things like this when I was company but now that I own the tractor I want to take care of the equipment best of my ability. Thanks! ","replyToPid":397803}
发表于 2020-9-18 09:21:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thought I would throw my 2 cents in here to. My outfit is running battery powered Apus . And as I gotta say nothing better ever","replyToPid":0}
发表于 2020-9-21 08:08:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"How often do you add this additive?","replyToPid":0}
发表于 2020-9-18 19:01:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"1500","replyToPid":0}
发表于 2020-12-14 10:39:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you considered an espar for heating your truck? They’re bout $1500 installed, read up on them","replyToPid":397803}
 楼主| 发表于 2020-9-18 06:40:42 来自手机 | 显示全部楼层
{"replyToPid":397812,"replyTo":"","text":"Thanks I just bought the truck and a some what used reefer and paid the insurance people. Don’t want to dip into the maintenance fund to buy an APU I’m on a search for a used or refurbished APU. Been driving since I was 22, just turned 27 been wanting to become an O/O since I started thought a Freightliner would be a good starter truck thanks for the info! "}
GMT+8, 2026-4-17 21:54 , Processed in 0.145060 second(s), 24 queries .
