查看: 237|回复: 3
Ohio to Kentucky
 楼主| 发表于 2020-9-17 10:35:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey drivers, if you are heading to KY from Ohio and usually take 62, you'll get stuck and have to get towed. 62 is no longer a truck route. Clearance is 13'5. Take 68 or go down towards Chillicothe. Be safe out there!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-17 11:13:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks 👍","replyToPid":0}
发表于 2020-9-17 23:11:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"if the tow truck can fit to tow youre truck out......how is it not possible for the truck by itself not be able to pass ????!!!!","replyToPid":0}
 楼主| 发表于 2020-9-20 06:27:17 来自手机 | 显示全部楼层
51458 发表于 2020-09-17 15:11:12 if the tow truck can fit to tow youre truck out......how is it not possible for the truck by itself not be able to pass ????!!!!
","text":"clearance is 13'5","replyToPid":397723}
GMT+8, 2026-2-7 11:43 , Processed in 0.079545 second(s), 24 queries .
