查看: 87|回复: 3
Air issue
 楼主| 发表于 2020-9-16 06:16:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Changed air drier, purge kit, 4 air bags, sleeper leveling valve, all kinds of fittings. Sprayed soapy water on every connection I could find. Air PSI is STILL dropping, building, popping off. When it pops off it sounds like a lazy rattle snake and then stops.\nAny ideas??\nDriving me knuckin futs!!!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-19 10:22:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does it leak when turned off?","replyToPid":0}
发表于 2020-9-30 19:46:55 来自手机 | 显示全部楼层
764614 发表于 2020-09-19 02:22:45 Does it leak when turned off?
","text":"if it seems to pop off every for 5 minutes while you're sitting there idling then the little line from the governor to the air dryer has a leak in it and it's letting pressure bleed off their which turns the compressor back on","replyToPid":397975}
发表于 2020-9-30 20:38:18 来自手机 | 显示全部楼层
815642 发表于 2020-09-30 11:46:55 if it seems to pop off every for 5 minutes while you're sitting there idling then the little line from the governor to the air dryer has a leak in it and it's letting pressure bleed off their which turns the compressor back on
","text":"Change the leaking line and see what it does. Also does your air pressure seem to drop quick on the gauges?","replyToPid":400273}
GMT+8, 2026-4-17 09:30 , Processed in 0.086816 second(s), 23 queries .
