查看: 150|回复: 10
Thanks for using cheap tires. Your thriftiness made me another load
 楼主| 发表于 2020-9-15 23:00:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"115 cubic yards of cheap tires \",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":918.0}]","canComment":true,"externalShare":false}
发表于 2020-9-16 11:01:12 来自手机 | 显示全部楼层
580577 发表于 2020-09-16 00:40:27 For LT Tires \nSailun , Hercules, GT Radial \nWill last just as long \nHalf the money ...\n\nSemi tires \nAgain ...Sailun , Hercules , Roadlux ..\nWill be rite there with Michelin. Quarter the money ...\nSpecially if ur doing quite a bit of gravel ,\n
","text":"This is the dumbest s  hit I’ve ever heard. ","replyToPid":397487}
发表于 2020-9-16 08:40:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"For LT Tires \nSailun , Hercules, GT Radial \nWill last just as long \nHalf the money ...\n\nSemi tires \nAgain ...Sailun , Hercules , Roadlux ..\nWill be rite there with Michelin. Quarter the money ...\nSpecially if ur doing quite a bit of gravel ,\n","replyToPid":0}
发表于 2020-9-16 07:57:40 来自手机 | 显示全部楼层
580577 发表于 2020-09-15 22:47:00 Michelin is  overrated
","text":"Michelin has never let me down. Not overrated. The best. 👌🏻 ","replyToPid":397468}
发表于 2020-9-16 06:02:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ha ha not me. Michelin only here 👌🏻 ","replyToPid":0}
发表于 2020-9-16 06:46:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I see a couple good year wrangler ,\nAnd there not cheap \nBut no good either ","replyToPid":0}
发表于 2020-9-16 06:47:00 来自手机 | 显示全部楼层
945974 发表于 2020-09-15 22:02:02 Ha ha not me. Michelin only here 👌🏻
","text":"Michelin is  overrated ","replyToPid":397442}
发表于 2020-9-16 11:03:20 来自手机 | 显示全部楼层
984141 发表于 2020-09-16 01:41:18 I just switched from Michelin to Bridgestone a couple weeks ago..saved over a hundred dollars a tire on 10 tires and didn't think the michelin was worth 1k extra when Bridgestone is good and made in USA..so far i am very happy with them..one of the Michelin tires had a huge crack forming in the sidewall where the tred meets the sidewall so don't know what's up with that kinda overrated..last michelin I had were made in Canada.  almost went with toyo
","text":"What Bridgestone did you go with? I always had good luck with the M726 👌🏻 when my previous truck was new it came with M710 drives.. hang on when it rains 😆 ","replyToPid":397490}
发表于 2020-9-16 20:52:07 来自手机 | 显示全部楼层
945974 发表于 2020-09-16 03:01:12 This is the dumbest s  hit I’ve ever heard.
","text":"We run 10 semi combo units \n8 1 ton truck combo units \nPlus a licensed tire dealer, and I circulate quite a few tires I imagine ...\nWith a lot of guys opting for a cheaper tire , \nWhich u can afford to buy almost three sets over 1 Michelin ,\n","replyToPid":397508}
发表于 2020-9-16 21:43:50 来自手机 | 显示全部楼层
{"replyToPid":397548,"replyTo":"
580577 发表于 2020-09-16 12:52:07 We run 10 semi combo units \n8 1 ton truck combo units \nPlus a licensed tire dealer, and I circulate quite a few tires I imagine ...\nWith a lot of guys opting for a cheaper tire , \nWhich u can afford to buy almost three sets over 1 Michelin ,\n
","text":"I only buy brand new Pete 389 trucks/Great Dane trailers. I’m not running low rent tires. Besides, I need the tax deduction 👌🏻 "}
GMT+8, 2026-2-7 11:42 , Processed in 0.072880 second(s), 25 queries .
