查看: 374|回复: 6
Load reset
 楼主| 发表于 2020-9-14 04:30:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi there fellow truckers I had a load of Pepsi and water that got all messed up like every single pallet shifted and the place I was supposed to deliver to refused to unload me 😒 what should I do ?? Tia ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-14 04:37:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not that this is any help now, but in my opinion I'd stay as far away as possible from Pepsi, Coke Etc!   I've been in that situation twice and never again!  Wound up taking it back to shipper...  waste of time and lose of money","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-9-14 04:48:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some loads are very difficult to move. You almost have to act like there’s an open cup of coffee on the dashboard and take it really easy on corners and acceleration and deceleration. If you’re out here long enough you will have some surprises like that so don’t feel bad. Live and learn. Call the contact responsible for the load, if no one is available Sunday call first thing in the morning and wait at a local truck stop. Good luck ","replyToPid":0}
发表于 2020-9-14 06:40:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thats happened to me before to, Do as all 3 of these guys suggest👆🏼.","replyToPid":0}
发表于 2020-9-15 05:43:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"How about these guys that haul eggs? ","replyToPid":0}
发表于 2020-9-28 05:54:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"good suggestions","replyToPid":0}
发表于 2020-9-28 06:23:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"My suggestion is pull an air ride trailer. I move a lot of beverages and have never had an issue. If it don’t look we’ll shrink wrapped l put 2-3 stamps on it before I seal my trailer. If you are on a rough road slow down. If you will be going above 6000’ the air bags the put in to secure the load can pop. I was coming over Loveland pass one time and kept hearing these explosions had no idea what it was till I opened my trailer doors. ","replyToPid":0}
GMT+8, 2026-2-12 07:38 , Processed in 0.125186 second(s), 24 queries .
