查看: 352|回复: 12
Camera inside trailer to watch your loading process
 楼主| 发表于 2020-9-12 07:30:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi my dear friends, I saw somewhere video with installation of camera inside the trailer to monitor loading/unloading process, but now I can’t find it. Can anyone recommend camera & installation guide. Thank you!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-13 01:10:03 来自手机 | 显示全部楼层
945974 发表于 2020-09-12 03:09:08 This day in age even if you caught the damage on video it’s probably illegal to record them without consent 😆 but it is a great idea 👌🏻
","text":"if you place the camera at the rear of the trailer facing in, technically you are recording your property. there is no \"expectation of privacy\" if someone enters your property and is captured on film.","replyToPid":396971}
回复 支持 7 反对 0
发表于 2020-9-12 09:29:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy a nanny cam and you can keep an eye on them and you can even talk to them while they load you. 😂😂😂😂","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-9-12 11:09:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"This day in age even if you caught the damage on video it’s probably illegal to record them without consent 😆 but it is a great idea 👌🏻 "}
回复 支持 4 反对 1
发表于 2020-9-12 13:33:08 来自手机 | 显示全部楼层
658864 发表于 2020-09-12 01:29:09 Buy a nanny cam and you can keep an eye on them and you can even talk to them while they load you. 😂😂😂😂
","text":"Good idea 😂😂👍🏼Imagine telling them to hurry the F up","replyToPid":396961}
发表于 2020-9-13 08:32:23 来自手机 | 显示全部楼层
200820 发表于 2020-09-12 05:33:08 Good idea 😂😂👍🏼Imagine telling them to hurry the F up
","text":"😂😂😂 or Say in a creepy voice “ I see you” ","replyToPid":396980}
 楼主| 发表于 2020-9-12 19:42:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"You place a sticker inside of your trailer, and after that your can record them. ","replyToPid":0}
发表于 2020-9-13 03:42:15 来自手机 | 显示全部楼层
479278 发表于 2020-09-12 17:10:03 if you place the camera at the rear of the trailer facing in, technically you are recording your property. there is no \"expectation of privacy\" if someone enters your property and is captured on film.
","text":"You should be able to record people without consent.  Screw this crooked mafia shippers.","replyToPid":397006}
发表于 2020-9-12 07:40:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s on your own trailer, you can just grab a remote camera with WiFi and mount it inside. You could run power from your pigtail through a hole in the wall that you seal with silicone sealant. Hardworking one is a bit more involved 🙂","replyToPid":0}
发表于 2020-9-12 08:19:48 来自手机 | 显示全部楼层
652642 发表于 2020-09-11 23:45:18 Yeh, but there is a billions of wi-fi cameras. I was thinking maybe someone has installed it already and is happy with it and can share his experience
","text":"I gotcha. I think the worst part would be in having adequate lighting inside. Give YouTube a shot, I’d bet there’s several vids about it there!","replyToPid":396954}
 楼主| 发表于 2020-9-12 08:49:06 来自手机 | 显示全部楼层
792671 发表于 2020-09-12 00:19:48 I gotcha. I think the worst part would be in having adequate lighting inside. Give YouTube a shot, I’d bet there’s several vids about it there!
","text":"Night-vision works pretty good. I saw somewhere video (I think here, but not sure)  of a trucker explaining what camera and how he connected it, and I remember his camera were facing trailer front, so warehouses couldn’t complain that he is spying them, and with night-vision it was perfectly visible whole trailer inside. YouTube gives only Trailer Cameras as backup for campers, found 1 with horse trailer for 2 horses, but still, will wifi or radio work at 53’ range? Do I need to have a possibility to record video? Im looking that kind of experience with pros and cons, if someone has, of course.","replyToPid":396957}
 楼主| 发表于 2020-9-12 07:45:18 来自手机 | 显示全部楼层
792671 发表于 2020-09-11 23:40:28 If it’s on your own trailer, you can just grab a remote camera with WiFi and mount it inside. You could run power from your pigtail through a hole in the wall that you seal with silicone sealant. Hardworking one is a bit more involved 🙂
","text":"Yeh, but there is a billions of wi-fi cameras. I was thinking maybe someone has installed it already and is happy with it and can share his experience ","replyToPid":396952}
GMT+8, 2026-2-4 22:05 , Processed in 0.114118 second(s), 24 queries .
