查看: 145|回复: 5
Question
 楼主| 发表于 2020-9-11 07:56:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"When I plug my fan into the 12v outlet my tv signal goes static or out completely. I use an antenna to pick up channels in the area. Does anyone know why this happens? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-11 09:38:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"First guy is right and Fuddy Duddy well he is right too mmmhhhuuuu","replyToPid":0}
发表于 2020-9-11 09:03:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Electronic interference from your fan. You need a filter between the tv and the power source, otherwise the electric feedback from the fan motor will just keep going through. \n\nAlso, if you’re using the same outlet for both, plus the fan into a different one and see if it helps. ","replyToPid":0}
发表于 2020-9-11 09:22:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s 2020, who the hell is watching broadcast TV? You old fuddy duddy","replyToPid":0}
发表于 2020-9-11 16:39:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"They still broadcast Television?  Who knew!!","replyToPid":0}
发表于 2020-9-11 23:43:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"be careful. I got under someone's skin when I talked about TV reception 🤣🤣🤣 I have an external drive with movies on it so I never have to worry about signal or satellite.","replyToPid":0}
GMT+8, 2026-2-12 17:35 , Processed in 0.057582 second(s), 24 queries .
