查看: 337|回复: 6
I don't get it🤯
 楼主| 发表于 2020-9-8 07:33:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"This parking lot is huge. Last night it didn't even fill up. I picked a spot at the back of the parking lot to park...away from everyone. Here comes the loud idiling pro star and a nose diving land star sucking up all my great antenna reception. Guess I'll break out my external drive with movies😷","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-8 12:27:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I see this type of complaint on here often, and it’s so dam silly. You are a trucker, in a truck stop, with other truckers. Not everyone parks the way you do. Diesel engines are loud, reefers are necessary to keep stuff cold, APUs are gonna be out there, too. It’s so narcissistic to complain about a truck parking next to you in a truckstop, regardless of how many spaces are open. If your primary concern is your antenna reception in the evenings then I don’t think your priorities are in order, perhaps you should get a local job, not everyone is cut out for this lifestyle and that’s ok. ","replyToPid":0}
回复 支持 12 反对 5
发表于 2020-9-8 13:09:55 来自手机 | 显示全部楼层
1003841 发表于 2020-09-08 04:27:46 I see this type of complaint on here often, and it’s so dam silly. You are a trucker, in a truck stop, with other truckers. Not everyone parks the way you do. Diesel engines are loud, reefers are necessary to keep stuff cold, APUs are gonna be out there, too. It’s so narcissistic to complain about a truck parking next to you in a truckstop, regardless of how many spaces are open. If your primary concern is your antenna reception in the evenings then I don’t think your priorities are in order, perhaps you should get a local job, not everyone is cut out for this lifestyle and that’s ok.
","text":"Thank you for your advice.","replyToPid":396476}
发表于 2020-9-11 01:04:47 来自手机 | 显示全部楼层
963479 发表于 2020-09-09 20:21:35 You're assuming I'm new. I'm not. In short, your asinine rhetoric is superfluous. It was a simple observation.
","text":"Well I said it once, and some little snowflake had it taken down. I’m not assuming you’re new, I’m just acknowledging that your soft. ","replyToPid":396601}
发表于 2020-9-8 12:13:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I parked in a very large dirt lot in nowhere Wyoming in the farthest corner. Next thing I know a guy in an old noisy Kenworth parks right next to me and idles all night. what the heck? lot easily holds 40 trucks and maybe 5 trucks were parked in it.","replyToPid":0}
 楼主| 发表于 2020-9-10 04:21:35 来自手机 | 显示全部楼层
","text":"You're assuming I'm new. I'm not. In short, your asinine rhetoric is superfluous. It was a simple observation.","replyToPid":396476}
发表于 2020-9-9 02:14:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yup if you establish a line others will follow the template every time!","replyToPid":0}
GMT+8, 2026-2-12 15:58 , Processed in 0.055429 second(s), 24 queries .
