查看: 659|回复: 19
Economy mode?
 楼主| 发表于 2020-9-6 06:34:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"Boss finally replaced my old T680 with a 2021 Cascadia. Its got the DD15 and automated 12 speed. I love the truck but hate driving it. its in economy mode. Can't maintain a steady speed for nothing. Constantly shifts out of gear to coast. Wind up coasting down hills at 61mph in a 65 zone. It's governed at 75 the truck is just gutless. Grossing 74k. Not light but not heavy either. But can't get going or pass or get over a hill so 75 is useless. Would the truck perform better with the trans in some other mode? Would MPG be greatly affected? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-9-6 08:01:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"75/80 is not heavy to you? That's 94% max. You're an f-en itTit and your opinion is null and void. Leave it in auto and let it think for you.","replyToPid":0}
回复 支持 0 反对 5
发表于 2020-9-6 08:23:05 来自手机 | 显示全部楼层
766797 发表于 2020-09-06 00:10:29 😄😂🤪you're funny boy👍👍👍
","text":"yeh, facts are funny to you. You know what makes something funny? It's when your mind projects and predicts and the outcome deviates from your expectations. Sad that you find facts funny.","replyToPid":396115}
回复 支持 0 反对 4
发表于 2020-9-6 08:30:32 来自手机 | 显示全部楼层
766797 发表于 2020-09-06 00:28:38 yes fact is 80k load is regular loads over it are heavy boy...👍🇺🇲
","text":"do you still carry a club? Your English is so bad...","replyToPid":396126}
回复 支持 0 反对 4
发表于 2020-9-6 08:08:40 来自手机 | 显示全部楼层
766797 发表于 2020-09-06 00:06:56 75/80 are regular loads😇😄👍🇺🇲
","text":"regular loads are heavy...dumpas","replyToPid":396111}
回复 支持 0 反对 3
发表于 2020-9-6 08:44:16 来自手机 | 显示全部楼层
no boy I don't need it but is good enough for you to understand and losing your time wit me🤣😅👍🇺🇲
{"replyToPid":396129,"replyTo":"
766797 发表于 2020-09-06 00:32:40 no boy I don't need it but is good enough for you to understand and losing your time wit me🤣😅👍🇺🇲
","text":"you might as well speak Spanish...and I might as well speak Cynese, that's why you will stay homoerectis.\n\nI'm a generous person, I give my time to anyone."}
回复 支持 0 反对 3
禁止发言
发表于 2020-9-6 10:37:07 来自手机 | 显示全部楼层
发表于 2020-9-6 20:28:04 来自手机 | 显示全部楼层
1007579 发表于 2020-09-06 00:01:45 75/80 is not heavy to you? That's 94% max. You're an f-en itTit and your opinion is null and void. Leave it in auto and let it think for you.
","text":"In your safe box of underachieving idiocy....\n        I know of plenty of drivers who are 50,000 empty and a minimum of 120,000 loaded. Just because the majority is running less than 80,000, doesn’t mean that is a heavy load 🙄","replyToPid":396107}
发表于 2020-9-8 07:44:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dude, I drove one. Hated every mile. Changed companies and I'm back in a KW","replyToPid":0}
发表于 2020-9-6 08:59:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a mechanic to open it up, he can reprogram that with a lap top, ask small shops around , my canadian truck was locked at 65mpg , my mechanic opened it to 87mpg 300$ , just pay some mechanic to do it","replyToPid":0}
发表于 2020-9-6 10:57:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"peddle the hammer down for override while in cruise mode"}
 楼主| 发表于 2020-9-6 07:10:34 来自手机 | 显示全部楼层
766797 发表于 2020-09-05 22:58:30 1.shift it manualy\n2. on shifter  should be position or switch you can choose regular or eco....
","text":"its locked into Economy. Manual not allowed. I can paddle up and down to change gears but within a few seconds it just goes right back to the higher gear.","replyToPid":396095}
发表于 2020-9-6 07:30:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"put selector in manual and geaux for it","replyToPid":0}
发表于 2020-9-6 07:33:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"ackkk just saw petes message.. yeah if its doing that then ur screwed unless u and head mechanic are on beer drinkn terms","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.117207 second(s), 24 queries .
