查看: 211|回复: 6
Did someone hauled the load of eggs before. I put my refer on 37 as they told me but its staying at 48 even after 8 hr
 楼主| 发表于 2020-9-2 09:17:16 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-9-2 21:59:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Loads will do that when they are warm it takes awhile to get the load to temp it happens all the time ","replyToPid":0}
发表于 2020-9-3 00:14:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not a load of eggs, but I had a load of cabbage that was warm, the reefer had a hard time keeping the temperature low. What I found out it works was setting the temperature by 1 degree lower every 30-50 miles. Lots of stops, but when I got there it was in  the range they accept. I did have a recorder in the trailer which showed a higher temperature at some point. They ended up receiving the load “ under protest”. But that was cabbage... ","replyToPid":0}
发表于 2020-9-2 09:41:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"34-37 degrees .. better hope you don’t have a temp recorder inside your trailer 😆 try manual defrost and set at 34 degrees ","replyToPid":0}
发表于 2020-9-2 09:35:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re screwed","replyToPid":0}
 楼主| 发表于 2020-9-2 19:10:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"So you guy actually know when you deliver load of egg","replyToPid":0}
 楼主| 发表于 2020-9-12 22:28:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"They took my load all is well lol","replyToPid":0}
GMT+8, 2026-2-10 05:15 , Processed in 0.071602 second(s), 24 queries .
