查看: 336|回复: 10
Ppl pls advise which route is safe to take? thanks Going from Mcallen to Philadelphia
 楼主| 发表于 2020-8-29 09:52:32 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1506.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true,"externalShare":false}
发表于 2020-8-29 12:12:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"he asked if it  is safe to go through Atlanta!","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-8-29 12:14:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d take the furthest north route, probably less hurricane damage","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-8-29 11:55:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is why you buy a motor carrier road atlas.  it'll answer these questions without having to rely on others. look at your route,  then check the highway you're taking for restrictions and clearance issues","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-8-29 20:24:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"if going to Atlanta take the southern loop","replyToPid":0}
发表于 2020-8-29 19:43:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"The two on right are “safe” basically 81N to PA turnpike into Philly. Pretty simple ","replyToPid":0}
发表于 2020-8-29 12:57:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"No way safe way. ","replyToPid":0}
发表于 2020-8-30 00:52:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always take the quickest route and watch your signs and don't drive through big cities at night when all the meth head soros dipshits are out n about","replyToPid":0}
发表于 2020-8-29 19:28:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on how hard the gulf coast got hit this week. Any of the will fine as it’s almost all major highways. Look at you timing to hopefully avoid rush hour in Atlanta and DC, though","replyToPid":0}
发表于 2020-8-29 17:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hopefully you're not relying on Google maps in the east coast. Get yourself an atlas, or a trucker GPS. If I-10 is open id take that to Atlanta to Richmond  to Philly.","replyToPid":0}
 楼主| 发表于 2020-8-30 03:09:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey thank u so much for the support dear drivers ✊ I took the fastest route. Currently I am at I59 Alabama and thanks god the road was smooth. \nbtw, I use garmin but always put google map in a cities 😉 take care all ","replyToPid":0}
GMT+8, 2026-2-10 08:53 , Processed in 0.068253 second(s), 24 queries .
