查看: 96|回复: 8
gps
 楼主| 发表于 2020-8-28 06:40:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"does anybody have any input on GPS is I have a Garman tracker that works terrible it's hard to input and if it reroute you it'll take you down dirt roads and alleys and wherever it wants to","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-8-28 08:37:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's all in the settings","replyToPid":0}
发表于 2020-8-28 20:41:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"GPS is a means to get lost in even more inaccessible places. Know before you go.  Don't rely on GPS, check maps before you move the truck and do old school of mentally noting your routes.","replyToPid":0}
发表于 2020-8-28 13:16:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmins Dezls are easy to use. My grandmother figured it out and she’s dead. What’s your excuse?\n\nBtw, you need to set it up for the vehicle you have, etc. There’s also a warning on the first screen when it boots up, telling you that you need to pay attention and use common sense. Don’t pull a Swift and go down dirt roads you’re not familiar with ","replyToPid":0}
发表于 2020-8-28 11:10:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"pull over and Google maps.","replyToPid":0}
发表于 2020-8-28 15:35:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Garmin Dezl. Love it! Very user friendly. ","replyToPid":0}
发表于 2020-8-28 19:52:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"All GPS’ do that. You have to use a combination of GPS, map book and google maps. Don’t forget the biggest component, common sense.","replyToPid":0}
 楼主| 发表于 2020-8-29 01:02:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"gotcha you would think somebody would make one that works just send them back to the manufacture and get the money back use the map , thanks for all the replies","replyToPid":0}
发表于 2020-8-29 12:17:42 来自手机 | 显示全部楼层
847795 发表于 2020-08-28 17:02:17 gotcha you would think somebody would make one that works just send them back to the manufacture and get the money back use the map , thanks for all the replies
","text":"I have a Garmin OTR 700, it works really well. You can do updates over Wi-Fi with it. Last update I did was at Iowa 80 using their WiFi. Took about 30 minutes, did it right before I went to sleep. When I woke up, it was all ready to go. My trainer has older 600 dezl from Garmin, you have to use a computer to update it. It's a lot slower, but still works better than Rand McNally GPS.","replyToPid":394974}
GMT+8, 2026-2-10 08:53 , Processed in 0.065694 second(s), 24 queries .
