查看: 228|回复: 7
help plz spn 520372 mf 14
 楼主| 发表于 2020-8-27 14:00:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"check engine light is on, DEF light blinking, derate to 55mph... can't find code on google... 2017 dd15 Cascadia","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2312.0,\"name\":\"\",\"url\":\"\",\"width\":1042.0}]","canComment":true,"externalShare":false}
发表于 2020-8-28 05:54:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"eject button","replyToPid":0}
发表于 2020-8-27 21:02:22 来自手机 | 显示全部楼层
128142 发表于 2020-08-27 12:51:46 FIELD SERVICE CAMPAIGN BULLETIN Subject: Field Service Campaign D18M2 GHG17 Detroit™ DD13® Software Reprogramming and Emission Label Replacement for Motor Coach Industries, Inc. (MCI®) Issue Involved Detroit Diesel Corporation (DDC) has determined that some certified GHG17 Detroit™ DD13® engines installed in MCI® vehicles will require reprogramming to a minimum of the software and fuel map part number ZGS levels listed below.  MCM software 6.6.0.1 with fuel map part number level ZGS 003  ACM software 7.58.2.0 with fuel map part number: o A0194486954 ZGS 001 (engine serial number 471941S0547134 and higher) o A0194487054 ZGS 001 (engine serial number 471941S0547132 and lower)  CPC software R40_00_000A Some of these units may also need their exempt emission label replaced with a certified emission label. Updated programming and certified emission labels became effective for GHG17 DD13® engines manufactured after August 29, 2018. GHG17 DD13® engines manufactured before August 29, 2018, need the MCM, ACM, and CPC reprogrammed, and some may also need installation of a certified emission label. Note that some engines may already be reprogrammed and have a certified emission label installed. These engines will be excluded from this Field Service Campaign. Reprogramming and emission label replacement corrects various fault code issues such as “SPN: 1636, FMI: 16 – CAC Efficiency Low”, “SPN: 2659, FMI: 0 – EGR Flow Target Error”, and “SPN: 520372, FMI: 16 – SCR Closed Loop Control At Maximum Limit.” There are approximately 457 engines affected by this Field Service Campaign.
","text":"He said it's a 2017 with a dd15","replyToPid":394808}
发表于 2020-8-27 19:48:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you driving ??","replyToPid":0}
发表于 2020-8-27 20:51:46 来自手机 | 显示全部楼层
128142 发表于 2020-08-27 12:51:38 Take it in.  It's listed under a service bulletin, should be free to fix, but only a dealer can hit this one.  It's new software time.
","text":"FIELD SERVICE CAMPAIGN BULLETIN Subject: Field Service Campaign D18M2 GHG17 Detroit™ DD13® Software Reprogramming and Emission Label Replacement for Motor Coach Industries, Inc. (MCI®) Issue Involved Detroit Diesel Corporation (DDC) has determined that some certified GHG17 Detroit™ DD13® engines installed in MCI® vehicles will require reprogramming to a minimum of the software and fuel map part number ZGS levels listed below.  MCM software 6.6.0.1 with fuel map part number level ZGS 003  ACM software 7.58.2.0 with fuel map part number: o A0194486954 ZGS 001 (engine serial number 471941S0547134 and higher) o A0194487054 ZGS 001 (engine serial number 471941S0547132 and lower)  CPC software R40_00_000A Some of these units may also need their exempt emission label replaced with a certified emission label. Updated programming and certified emission labels became effective for GHG17 DD13® engines manufactured after August 29, 2018. GHG17 DD13® engines manufactured before August 29, 2018, need the MCM, ACM, and CPC reprogrammed, and some may also need installation of a certified emission label. Note that some engines may already be reprogrammed and have a certified emission label installed. These engines will be excluded from this Field Service Campaign. Reprogramming and emission label replacement corrects various fault code issues such as “SPN: 1636, FMI: 16 – CAC Efficiency Low”, “SPN: 2659, FMI: 0 – EGR Flow Target Error”, and “SPN: 520372, FMI: 16 – SCR Closed Loop Control At Maximum Limit.” There are approximately 457 engines affected by this Field Service Campaign.","replyToPid":394807}
发表于 2020-8-27 20:51:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take it in.  It's listed under a service bulletin, should be free to fix, but only a dealer can hit this one.  It's new software time.","replyToPid":0}
发表于 2020-8-28 05:49:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not sure if the code was the same, but I had pretty much the same symptoms happen to me about a year ago. Issue was the DEF NOX sensor ","replyToPid":0}
 楼主| 发表于 2020-10-8 08:44:13 来自手机 | 显示全部楼层
731716 发表于 2020-08-27 21:49:05 Not sure if the code was the same, but I had pretty much the same symptoms happen to me about a year ago. Issue was the DEF NOX sensor
","text":"thanks bro it was actually the DEF problem. had to change all the components and get the tank n filter cleaned. cause by bad DEF fluid at Esso truck stop in Canada. cost me big","replyToPid":394856}
GMT+8, 2026-2-9 22:39 , Processed in 0.098343 second(s), 24 queries .
