查看: 96|回复: 3
help please spn 520372 FMI14
 楼主| 发表于 2020-8-27 13:56:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"check engine light came on and DEF light blinking... can't find the code anywhere on google. power derate to 55mph ... all other gages are in perfect levels ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2312.0,\"name\":\"\",\"url\":\"\",\"width\":1042.0}]","canComment":true,"externalShare":false}
发表于 2020-9-2 09:58:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was at peterbilt shop when I seen this so I asked if they knew and he said you must have a Detroit it most likely just needs a software update","replyToPid":0}
 楼主| 发表于 2020-10-8 08:41:28 来自手机 | 显示全部楼层
820767 发表于 2020-09-02 01:58:37 I was at peterbilt shop when I seen this so I asked if they knew and he said you must have a Detroit it most likely just needs a software update
","text":"thanks man. i had to change the entire DEF components cost me big","replyToPid":395531}
发表于 2020-10-15 10:02:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"What was the problem?\n\nMy suggestion was going to be your DPF doser. ","replyToPid":0}
GMT+8, 2026-4-17 11:08 , Processed in 0.099997 second(s), 24 queries .
