查看: 407|回复: 12
is this possible to drive from California with the tandoms set at 10 ft
 楼主| 发表于 2020-8-22 01:14:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"is it possible to drive from California with the tandoms at 10 ft ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-8-22 22:58:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ive been trucking for 9 years. I wont go to California or east of Ohio. There’s no money out there. And California hates truckers so they can eat dirt for all i care. ","replyToPid":0}
回复 支持 5 反对 2
发表于 2020-8-22 09:35:10 来自手机 | 显示全部楼层
936953 发表于 2020-08-22 00:53:49 They won’t look twice at your steer weight. Your only limited by the axle your truck is equipped with up to 20,000 pounds. Check the tag inside the drivers door. It should say the axle rating for your steer. Common ones are 12k, 12.5k 13.2k
","text":"Steer axle weight means nothing unless you’re running 16 ply tires to account for it. Marion, IL southbound scale on I-57 parked me on the platform during the night once. Scale master literally came outside with a flashlight so he could read my max weight for each steer tire 😂 ","replyToPid":394287}
发表于 2020-8-23 05:20:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"My private fleet doesn't have those problems","replyToPid":0}
 楼主| 发表于 2020-8-22 06:05:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"is 12160 passable or is that also a no no","replyToPid":0}
发表于 2020-8-22 08:53:49 来自手机 | 显示全部楼层
854978 发表于 2020-08-21 22:05:28 is 12160 passable or is that also a no no
","text":"They won’t look twice at your steer weight. Your only limited by the axle your truck is equipped with up to 20,000 pounds. Check the tag inside the drivers door. It should say the axle rating for your steer. Common ones are 12k, 12.5k 13.2k","replyToPid":394276}
发表于 2020-8-22 07:00:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"steers yes trailer no","replyToPid":0}
发表于 2020-8-22 05:39:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"The obvious answer is no. How do you expect to get out of CA over weight on the trailer ","replyToPid":0}
发表于 2020-8-23 02:39:34 来自手机 | 显示全部楼层
673275 发表于 2020-08-22 14:58:10 Ive been trucking for 9 years. I wont go to California or east of Ohio. There’s no money out there. And California hates truckers so they can eat dirt for all i care.
","text":"Lmao keep thinking that and I’ll keep hauling for $3-$4/mile to the states you won’t run 👌🏻 ","replyToPid":394340}
 楼主| 发表于 2020-8-22 04:00:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes I'm at 40ft","replyToPid":0}
发表于 2020-8-22 12:12:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"48' rule in ca if you run a 48' trl its exempt from 40' rule can have them tandems all the way back","replyToPid":0}
发表于 2020-8-22 02:05:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"40ft max allowed from center of kingpin to center or fear axle. On my trailer, I can go back 7 pin holes. depends on trailer though.","replyToPid":0}
GMT+8, 2026-2-10 10:35 , Processed in 0.096205 second(s), 24 queries .
