查看: 91|回复: 0
Need Help!!!
 楼主| 发表于 2019-1-28 16:10:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2017 579 Pete and I've got a problem that has existed since day 1. At first I installed a stock 4 wat cb radio with the stock antenna and coax and when I'd key up it would kill my cruise control or fast idle and cause a fault. So I changed the coax and mounted another antenna and ran hot & ground wires directly to the battery, but it still does it. It will even do it sometimes when another driver keys up beside of me. After doing it enough times the cruise won't come back on until I go to the shop and have them clear all the faults. Nobody has a solution, not even Peterbuilt. SOMEBODY PLEASE HELP ME !!!","pics":"[]","canComment":true}
GMT+8, 2026-4-16 05:14 , Processed in 0.077774 second(s), 23 queries .
