查看: 164|回复: 8
Questions.
 楼主| 发表于 2020-8-19 05:01:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone drive thur AZ I-17 how was it?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-8-19 05:31:48 来自手机 | 显示全部楼层
147103 发表于 2020-08-18 21:22:41 lots of long pulls if your heavy.
","text":"My load weight about 34k, from franklin IN to Tolleson AZ. U think is ok i take I 17?","replyToPid":393918}
禁止发言
发表于 2020-8-19 05:22:41 来自手机 | 显示全部楼层
发表于 2020-8-19 09:02:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a great road, just watch your speed heading south!","replyToPid":0}
发表于 2020-8-19 06:02:46 来自手机 | 显示全部楼层
446935 发表于 2020-08-18 21:31:48 My load weight about 34k, from franklin IN to Tolleson AZ. U think is ok i take I 17?
","text":"Hundreds of trucks travel I-17 everyday. Going south is easier than going north. 👌🏻 ","replyToPid":393919}
发表于 2020-8-19 05:09:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a good pull.. enjoy the scenery 🌵 ","replyToPid":0}
发表于 2020-8-19 07:43:28 来自手机 | 显示全部楼层
","text":"17 is fine, there’s a long grade on it heading south but it’s not that bad and levels out several times. It’s well marked.","replyToPid":393919}
发表于 2020-8-19 23:01:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"5% steep downgrade heading into Phoenix and a 6% heading north to flagstaff.  You’ll be fine driver, it’s probably nothing you haven’t dealt with before.  Just relax and go at 45-55MPH and try to keep in that speed. God bless.","replyToPid":0}
发表于 2020-8-19 23:02:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"But ultimately, you are the captain of your operation, you do what you feel is SAFE.  Everything else is secondary and tertiary.","replyToPid":0}
GMT+8, 2026-4-18 02:24 , Processed in 0.088479 second(s), 24 queries .
