查看: 283|回复: 8
Post Trip Inspection
 楼主| 发表于 2020-8-13 07:34:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was told from dispatch that a post trip inspection is not necessary to enter into my electronic log after my day is completed! I can do a post on my trailer, then go straight to Personal Convenience and drive 12 miles home and log off duty!  Anyone know why this would be?  I do 99% drop and hook daily!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-8-13 08:45:06 来自手机 | 显示全部楼层
760408 发表于 2020-08-12 23:51:17 so there's no need for a post trip inspection?  I can go home and log off duty with no post trip on truck til next morning and go straight to a pre trip inspection?
","text":"Post trip is not required, it might be recommended though depending on the company you work for. As an o/o I never put it on elog, even if I actually do it. ","replyToPid":393350}
发表于 2020-8-13 08:34:35 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"because most of us aren't drones, and the government should not be micromanaging our every activity. In the spirit of the law, so long as you are driving safe these little details do not matter. You can get off duty and jump into your personal car and drive another 24 hours and no one's going to stop you."}
发表于 2020-8-13 18:13:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"My understanding of post trip from my wife's company is it's for the company to set up any repair or relay that might be needed during your 10. They don't push it, and I understand their reasoning, but it can disrupt your clock. Unless there's something major going on she leaves it until pretrip. Putting a \"clean\" pretrip on the Qualcomm is essentially telling anybody checking that the truck was ok up until that point. When we go home she uses pc time.","replyToPid":0}
 楼主| 发表于 2020-8-13 07:51:17 来自手机 | 显示全部楼层
295387 发表于 2020-08-12 23:37:29 Because your going home
","text":"so there's no need for a post trip inspection?  I can go home and log off duty with no post trip on truck til next morning and go straight to a pre trip inspection?","replyToPid":393348}
发表于 2020-8-13 07:37:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Because your going home ","replyToPid":0}
 楼主| 发表于 2020-8-13 08:55:57 来自手机 | 显示全部楼层
670977 发表于 2020-08-13 00:45:06 Post trip is not required, it might be recommended though depending on the company you work for. As an o/o I never put it on elog, even if I actually do it.
","text":"appreciate the information! thank you","replyToPid":393360}
发表于 2020-8-14 02:05:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Post trip is required at the end of each shift. Before you personal home would be the end of the shift. Post trip both the truck and trailer. Then personal home.","replyToPid":0}
发表于 2020-8-14 02:11:17 来自手机 | 显示全部楼层
","text":"Post trips certainly are required under 396.11. You are not required to complete a DVIR if no defects are found but nothing exempts you from conducting the post trip inspection.","replyToPid":393360}
GMT+8, 2026-2-10 12:17 , Processed in 0.057992 second(s), 24 queries .
