查看: 288|回复: 12
Loads over 70,000 gross
 楼主| 发表于 2020-8-11 21:51:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it better to have more weight on drives or tandems? Does it really matter?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-8-12 00:56:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its situational. If I am going to run in snow or have to drive in dirt or something i want it on my drives to give me grip. if it is good weather I put it on my trailer to save the tread on my drives.","replyToPid":0}
回复 支持 11 反对 0
发表于 2020-8-11 23:47:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"you want it as balanced as possible between drives and trailer, and heavier on drives than steer. That's physics optimized.","replyToPid":0}
发表于 2020-8-11 22:53:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always make my drives heavy so I can better feel what the weight is doing","replyToPid":0}
发表于 2020-8-12 04:40:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on road conditions and what tires \"I\" buy","replyToPid":0}
发表于 2020-8-12 04:07:23 来自手机 | 显示全部楼层
945722 发表于 2020-08-11 16:56:15 Its situational. If I am going to run in snow or have to drive in dirt or something i want it on my drives to give me grip. if it is good weather I put it on my trailer to save the tread on my drives.
","text":"Agreed.","replyToPid":393074}
禁止发言
发表于 2020-8-11 22:26:45 来自手机 | 显示全部楼层
发表于 2020-8-12 00:09:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did 5000 pounds more on my tandem . I was driving perfect ","replyToPid":0}
发表于 2020-8-12 03:50:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Balanced favoring drives","replyToPid":0}
发表于 2020-8-12 05:01:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"drives that way your trailer is not fighting you. try to get it equal\nuse this app\nTruckers Slide Calc\nit is almost spot on","replyToPid":0}
发表于 2020-8-11 22:42:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Better traction and less weight pushing ","replyToPid":0}
GMT+8, 2026-2-13 00:46 , Processed in 0.117109 second(s), 24 queries .
