查看: 269|回复: 6
I found this on the magnet !!!!
 楼主| 发表于 2020-8-10 08:26:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"does any one knows what is it? or what problem I'm about to have ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1134.0}]","canComment":true,"externalShare":false}
发表于 2020-8-11 03:37:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Spring from a valve, I’ll give $300 for the truck.","replyToPid":0}
禁止发言
发表于 2020-8-10 19:55:19 来自手机 | 显示全部楼层
发表于 2020-8-10 20:47:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with old . Looks like a valve keeper, get to a shop.","replyToPid":0}
发表于 2020-8-10 20:19:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s something that was cause a problem sooner than later","replyToPid":0}
发表于 2020-8-11 04:16:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"It does look like a keeper. there are 2 on every valve. if the other one is still there, you might be ok. but I wouldn't run it. get it to a shop ASAP. If that valve drops you'll have catastrophic engine failure( if that's the valve keeper of course)","replyToPid":0}
发表于 2020-8-11 17:33:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"well what happened?  was it yours and are you in the shop? I hate the shop. it is better to be punched in the  face. (by a butterfly)","replyToPid":0}
GMT+8, 2026-2-6 17:50 , Processed in 0.055620 second(s), 24 queries .
