查看: 84|回复: 0
2 2015 GU815's having starter problems
 楼主| 发表于 2019-1-28 16:09:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey guys,\nWe have 2 2015 Mack GU815's, both purchased new at the same time, both trucks in the last few months have been having an issue where the starter solenoid just clicks and wont turn over for several attempts. Batteries are at full charge, starters have been changed, wiring has been checked, one shop found a ground cable had worn through on the frame, but this did not affect the issue. Changing starters reduced the frequency of the issue.\n\nMack has no idea how to solve it and has suggested it could be the neutral switch on the transmission and to contact Allison.\n\nAnyone else had this issue and found a solution?","pics":"[]","canComment":true}
GMT+8, 2026-4-17 02:29 , Processed in 0.074981 second(s), 24 queries .
