查看: 217|回复: 2
2021 Cascadia electric AC/APU (BPHV) fault codes #12
 楼主| 发表于 2020-8-3 14:49:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi, I have a 21 Freightliner cascadia with the electric AC under the bunk utilizing optimized idle when batteries get too low. The issue I'm having is a fault code keeps popping up when I try to start the electric AC. it's flashing code 12. And the unit will not start. Anybody have any idea what this is?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-8-5 15:23:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s under warranty, take it to the dealer when you get some down time. You can run the truck for a/c in the meantime. There are ways to trick the auto shut off","replyToPid":0}
 楼主| 发表于 2020-8-17 00:17:10 来自手机 | 显示全部楼层
977252 发表于 2020-08-05 07:23:25 It’s under warranty, take it to the dealer when you get some down time. You can run the truck for a/c in the meantime. There are ways to trick the auto shut off
","text":"okay thanks much!","replyToPid":392130}
GMT+8, 2026-4-17 07:54 , Processed in 2.089909 second(s), 23 queries .
