查看: 248|回复: 7
2015 Lonestar electric APU
 楼主| 发表于 2020-8-2 10:14:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Question. This truck has an all electric APU, it works great, auto start and stop works fine. The problem I’m having is after I’ve had the engine shut off about 2 hours, my air pressure drops below 60 and the alarm starts beeping, I’ve got trailer and tractor brakes set, going to have the shop try to find where my leak is when I get home, but does anyone know how to shut off that alarm clock until I can get the leak fixed?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-8-3 08:11:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Key off, autu start on, dash alarms go off. The electric APU works great, it’s just that low air pressure alarm","replyToPid":0}
发表于 2020-8-2 23:14:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is no way to turn that off. Had that happen in my LT. Gotta get that air leak fixed. Mine had a slow leak at the transmission. ","replyToPid":0}
发表于 2020-8-2 11:28:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"ear plugs","replyToPid":0}
发表于 2020-8-2 12:49:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"My APU starts up without the truck on yours might to give it a shot","replyToPid":0}
 楼主| 发表于 2020-8-2 20:12:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine starts up on its own when the batteries get to a certain level, but the air pressure alarm starts beeping long before that. ","replyToPid":0}
发表于 2020-8-2 22:29:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"The low air alarm beeps when the engine is off? Huh?","replyToPid":0}
发表于 2020-8-2 23:12:40 来自手机 | 显示全部楼层
983197 发表于 2020-08-02 14:40:44 I thought same thing.  beeps without key on?
","text":"Yes because when auto start system is on all the dash stuff is turned on as well as the low air alarm. ","replyToPid":391712}
GMT+8, 2026-2-13 07:30 , Processed in 0.111706 second(s), 24 queries .
