查看: 229|回复: 4
truck Maintenance
 楼主| 发表于 2020-8-1 02:24:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2007 century freightliner with 1,072,030 miles on the dashboard,what would you have done to it at this point?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-8-1 06:14:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Park it on the south side of Chicago, get out and make tracks like your head is on fire and your àss is catching, and let your insurance handle the rest.","replyToPid":0}
发表于 2020-8-1 03:39:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do the rods and main bearings on bottom end. Most likely they will be fine but it’s peace of mind and not expensive. Keep your gear oils changed every 500000 miles. Other than that just keep close eye on everything and don’t be afraid to spend money on it. And don’t get discouraged. Whatever you replace most likely won’t ever need replaced again. I ran my last two trucks out to 1.4 million each. ","replyToPid":0}
发表于 2020-8-1 23:59:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I made more money with my truck after a million miles then before. Try to keep a few dollars handy for trannies and gears and maybe an overhaul,but still cheaper than payments and broke down again and again with this new electronic trucks. also if you're not scared to get dirty and fix a little your self you have it made.","replyToPid":0}
发表于 2020-8-3 16:08:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run the Rack (it’s a calibration of injectors & other internal components) plus mains and rods.","replyToPid":0}
GMT+8, 2026-4-17 23:50 , Processed in 0.109792 second(s), 24 queries .
