查看: 430|回复: 11
 楼主| 发表于 2020-7-31 07:27:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[]","canComment":false,"externalShare":false}
发表于 2020-7-31 08:36:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not one to haggle folks but your driving a semi truck with a trailer I’m assuming. Taking a picture of your E-Logs while in motion, all while not fully understanding your HOS??? You need to pull that rig over, 😤","replyToPid":0}
回复 支持 8 反对 5
发表于 2020-7-31 07:51:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Probably didn’t do your break with under 8 hours of drive time ","replyToPid":0}
发表于 2020-8-1 00:43:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"safety meetings, sign thick 2 inch books to get a job, but dont talk about a single , practical real world scenario? ? how these guys gonna plan a thousand mile delivery, or deliver anything on time ?  ","replyToPid":0}
发表于 2020-8-1 00:41:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"these peoples companies dont show them how to use this $&@$ ? ? ","replyToPid":0}
发表于 2020-7-31 20:31:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just read your message and you may already got your answer but in case you didn’t here is what’s going on. When you first start your clock you get 8 hrs to drive and 8 hrs before you have to take your 30 min break. That is the way it will show up on the e- log even though you may have more driving time then it shows. The “ Time to Violation “ is just letting you know that you must stop after that time has elapsed to take your 30 min break. Right after you take the break you will recover the remaining drive time which will be 3 more hrs. Hope that helps","replyToPid":0}
发表于 2020-7-31 09:21:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"you took your 30 minute break before completing 8 hours of driving/on duty!  If you take another 30 minute break off duty you'll gain your remaining time back","replyToPid":0}
发表于 2020-7-31 20:00:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I love the Canadian HOS","replyToPid":0}
 楼主| 发表于 2020-8-1 13:13:42 来自手机 | 显示全部楼层
909150 发表于 2020-07-30 23:51:45 Probably didn’t do your break with under 8 hours of drive time
","text":"I am under canadian rule. i assume that i do not need 30 min break in my 8 first 8 hours, but on this day i took 2 breaks of 30 mins, 1st in 8 hours and 2nd one after that","replyToPid":391453}
 楼主| 发表于 2020-8-1 13:16:32 来自手机 | 显示全部楼层
518050 发表于 2020-07-31 00:36:24 I’m not one to haggle folks but your driving a semi truck with a trailer I’m assuming. Taking a picture of your E-Logs while in motion, all while not fully understanding your HOS??? You need to pull that rig over, 😤
","text":"how does it proves that i am driving.\nAfter stopping Elog stays in Drive mode for couple of seconds.\ni took this picture when i was stoped and yes my seat belt was still on at that time.","replyToPid":391458}
GMT+8, 2026-4-17 21:42 , Processed in 0.106480 second(s), 24 queries .
