查看: 260|回复: 10
They say if you let fear hold you back you won't get anywhere.
 楼主| 发表于 2020-7-29 21:20:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"Soooo I'm thinking about buying a van. Used. What things do I steer away besides the mechanical end of it like the tires breaks air lines etc. What else? anything major. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-30 14:02:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy Great Dane well made ","replyToPid":0}
发表于 2020-7-30 07:14:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Check your landing gear and under carriage hit it with a hammer. Got one trailer that they put fresh paint on it but it had been in a flood so was rusted out first time I put weight on the landing gear it crumbled🤦🏻‍♂️"}
发表于 2020-7-29 23:06:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Besides your tires, breaks, and airlines. Look for damage, You can check the roof from the inside of the trailer. The floor you can walk up n down and feel for weak points. Also the cross members, make sure there not loose or bent. Then make sure the doors close fine, and if you can check the electrical( all the lights) that would be a piece of mind too.","replyToPid":0}
发表于 2020-7-31 02:30:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"go with your dream","replyToPid":0}
 楼主| 发表于 2020-7-30 09:31:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is a good idea thanks ","replyToPid":0}
 楼主| 发表于 2020-7-30 02:56:19 来自手机 | 显示全部楼层
200820 发表于 2020-07-29 15:06:35 Besides your tires, breaks, and airlines. Look for damage, You can check the roof from the inside of the trailer. The floor you can walk up n down and feel for weak points. Also the cross members, make sure there not loose or bent. Then make sure the doors close fine, and if you can check the electrical( all the lights) that would be a piece of mind too.
","text":"Thank you so much","replyToPid":391255}
发表于 2020-7-29 21:53:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"wait are you saying I should take dookies in the bread isle?","replyToPid":0}
发表于 2020-7-29 21:35:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"no comment","replyToPid":0}
 楼主| 发表于 2020-7-30 02:55:13 来自手机 | 显示全部楼层
983197 发表于 2020-07-29 14:06:38 look for structural damages and repairs.\nmany repair jobs I have seen are horrible. also floor bowing and waves.\ntry to climb up to roof if you can and make sure it didn't hit a bridge.
","text":"Thank you ","replyToPid":391252}
GMT+8, 2026-2-6 16:07 , Processed in 0.052795 second(s), 24 queries .
