查看: 755|回复: 24
steer axle weight alowance?
 楼主| 发表于 2020-7-29 07:00:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"hello how much weight can i have on my steers legally?\nim pulling a 53' flatbed\nive been messing with my 5th wheel now trying to get it to  perfect position \nthanks ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-29 08:18:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"This has to be a fake account. Between this and his girlfriend post. WTF","replyToPid":0}
回复 支持 4 反对 3
发表于 2020-7-29 08:43:42 来自手机 | 显示全部楼层
612134 发表于 2020-07-29 00:18:34 This has to be a fake account. Between this and his girlfriend post. WTF
","text":"I looked up the post your talking about and who in there right mind would waste 34hrs to hang with a girl that your not married to? Get in get out go make some money.","replyToPid":391163}
回复 支持 5 反对 1
发表于 2020-7-29 09:49:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"12,000 lbs.\n\n\nA trick a learned is slide the 5th wheel all the way back and adjust the tandems. It works MOST of the time. \n\nAlso make sure you scale AFTER you fuel.","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-7-29 07:51:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Up to 20,000 pounds, depends on the weight rating of your specific axle. Check the tag inside the door jamb.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-7-29 13:54:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Grab an atlas. It lists the state by state limits. Lowest is 12k for a single steer axle. Highest is 20k or manufacturers rating.","replyToPid":0}
发表于 2020-7-29 12:55:13 来自手机 | 显示全部楼层
896849 发表于 2020-07-29 04:32:52 20,000 if your axle is rated for it. I've got 13,200 on this truck.
","text":"In addition to Bridge Formula weight limits, Federal law states that single axles are limited to 20,000 pounds, and axles spaced more than 40 inches and not more than 96 inches apart (tandem axles) are limited to 34,000 pounds. Gross vehicle weight is limited to 80,000 pounds (23 U.S.C. 127).","replyToPid":391193}
发表于 2020-7-29 12:32:52 来自手机 | 显示全部楼层
984080 发表于 2020-07-29 01:40:41 im asking questions that i would like to know the answers too  im a new driver. dont really know why you would even reply and not answer the question.
","text":"20,000 if your axle is rated for it. I've got 13,200 on this truck. ","replyToPid":391176}
回复 支持 2 反对 2
发表于 2020-7-30 22:15:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"ranges from 12,700-13,300 ; and ive never been pulled over for weigh issues? i know the book says 12,000 on papers ; i think thats why this guy has the question on here; ive been driving for 16 years and i dont even know the steer axle question","replyToPid":0}
发表于 2020-7-30 22:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"my front axle is always over 12,000","replyToPid":0}
发表于 2020-10-15 09:53:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can have 12000 on steers. People are taking the 20000 pound on a single axle out of context. That is 20000 on a single axle with dual wheels. What it’s referring to is like a spread axle trailer 20000 on each axle for a total of 40000 on your trailer ","replyToPid":0}
 楼主| 发表于 2020-7-29 09:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"im asking questions that i would like to know the answers too  im a new driver. dont really know why you would even reply and not answer the question.","replyToPid":0}
发表于 2020-7-30 00:16:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"12000 lb","replyToPid":0}
GMT+8, 2026-4-16 12:24 , Processed in 0.198635 second(s), 24 queries .
