查看: 168|回复: 3
Problem with load
 楼主| 发表于 2020-7-29 05:33:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys My truck is overweight and I need to have some body come and move some boxes to back of the van do you have any experience with that?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-29 05:37:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's the shipper's responsibility.","replyToPid":0}
发表于 2020-7-29 06:24:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"shift your tandems depending on what state and if ur able to. otherwise go back to the shippier for readjustment.","replyToPid":0}
发表于 2020-7-29 08:31:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are already at inspection station, it's on you (moving company maybe).  otherwise,  go back to shipper with scale ticket and ask them to adjust it.  you are lucky it needs to be shifted to the rear instead of the other way around. it's no fun when they have to pull ALL of it off and do it again. \nbeen there, done that.","replyToPid":0}
GMT+8, 2026-2-13 07:31 , Processed in 0.113355 second(s), 24 queries .
