查看: 271|回复: 7
Deleted
 楼主| 发表于 2020-7-29 03:20:54 来自手机 | 显示全部楼层 |阅读模式
{"text":".","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2020-7-29 07:16:51 来自手机 | 显示全部楼层
回复 支持 3 反对 3
 楼主| 发表于 2020-7-29 07:57:36 来自手机 | 显示全部楼层
984141 发表于 2020-07-28 23:54:30 the tires also look like they are being run over inflated
","text":"They are auto inflated.","replyToPid":391160}
 楼主| 发表于 2020-7-29 07:43:37 来自手机 | 显示全部楼层
147103 发表于 2020-07-28 23:16:51 I understand your frustration.  Get yourself a short piece of 4x4 and a air hose.  Might save you time in the future. Air tires up yourself.
","text":"I appreciate your comment and you're right about how I can and should create my own solutions. Unfortunately, I'm not permitted to \"do work\" like that on this contract.","replyToPid":391149}
 楼主| 发表于 2020-7-29 07:48:04 来自手机 | 显示全部楼层
clearly looks like something in the tire tread on the left when zoomed in..what does that have to do with curbing ?
{"replyToPid":391156,"replyTo":"
984141 发表于 2020-07-28 23:45:08 clearly looks like something in the tire tread on the left when zoomed in..what does that have to do with curbing ?
","text":"Yes, you're right. This particular tire has a bolt in it. This was the first time the tire was punctured. Every other occasion it has just been knocked loose and has to be remounted after they remove and inspect the tire."}
发表于 2020-8-1 16:10:10 来自手机 | 显示全部楼层
619622 发表于 2020-07-28 23:43:37 I appreciate your comment and you're right about how I can and should create my own solutions. Unfortunately, I'm not permitted to \"do work\" like that on this contract.
","text":"omg a truck driving school Steering wheel Holder 💯😀","replyToPid":391155}
发表于 2020-8-1 16:12:15 来自手机 | 显示全部楼层
","text":"there's no way any truck company gave you a contract saying not to check your fluids and tire pressure. your a straight up swift driver 💯😀","replyToPid":391155}
 楼主| 发表于 2020-8-1 18:48:46 来自手机 | 显示全部楼层
978322 发表于 2020-08-01 08:12:15 there's no way any truck company gave you a contract saying not to check your fluids and tire pressure. your a straight up swift driver 💯😀
","text":"Okay 👌 Never said that but you figured it all out. Never drove for Swift, but I hear they are great 🤣🤣","replyToPid":391608}
GMT+8, 2026-2-13 05:48 , Processed in 0.099229 second(s), 24 queries .
