查看: 275|回复: 8
Log book
 楼主| 发表于 2020-7-29 00:33:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"when do you need ELD on your truck?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-29 02:04:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"generally if your engine is a 99 or newer model and you travel more than 150 air miles from where you report for and return to (yard or shop) every day., you will be required to use an ELD.","replyToPid":0}
发表于 2020-7-30 04:34:26 来自手机 | 显示全部楼层
618543 发表于 2020-07-29 01:38:17 yes asking if I need ELD on my truck or can I just use paper log? I drive a 2016 peterbilt. Payed hourly. Only travel Texas. Home every night. Sometimes.
","text":"With that info, I'd say you need to run logs","replyToPid":391175}
发表于 2020-7-29 01:04:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"what is it you need more specific information about","replyToPid":0}
发表于 2020-7-29 01:04:55 来自手机 | 显示全部楼层
发表于 2020-7-29 07:56:33 来自手机 | 显示全部楼层
65688 发表于 2020-07-28 18:04:30 generally if your engine is a 99 or newer model and you travel more than 150 air miles from where you report for and return to (yard or shop) every day., you will be required to use an ELD.
","text":"It’s 100 air miles. 150 is for non CDL. Changing to 150 in September for CDL","replyToPid":391103}
 楼主| 发表于 2020-7-29 09:38:17 来自手机 | 显示全部楼层
468347 发表于 2020-07-28 17:04:55 what is it you need more specific information about
","text":"yes asking if I need ELD on my truck or can I just use paper log? I drive a 2016 peterbilt. Payed hourly. Only travel Texas. Home every night. Sometimes.","replyToPid":391100}
发表于 2020-7-30 01:22:51 来自手机 | 显示全部楼层
","text":"If you travel more than 100 air miles away from your starting location (must start from same location every day) or work more than 12 hours ( from time start to finish of day) you need an ELD. You can go past theses limits 8 times in a rolling 30 day period. Each day you exceed those limits you need to fill out a paper log. If you hit 9 days in 30 rolling period you are required to keep an ELD","replyToPid":391175}
发表于 2020-7-30 04:34:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"ELD, excuse me","replyToPid":0}
GMT+8, 2026-3-22 00:32 , Processed in 0.074861 second(s), 24 queries .
