查看: 404|回复: 5
Truck drivers
 楼主| 发表于 2020-7-27 15:43:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"How can you accept load freight without dispatcher ? Will the load apps let me be able to accept loads ? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-27 17:54:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"your your dispatcher on accepting loads , you can use this app for load board as well, see something that you want click on it and it will give you the info and numbers to call.","replyToPid":0}
 楼主| 发表于 2020-7-27 19:41:16 来自手机 | 显示全部楼层
871257 发表于 2020-07-27 09:54:09 your your dispatcher on accepting loads , you can use this app for load board as well, see something that you want click on it and it will give you the info and numbers to call.
","text":"I don’t have to be an authority for a certain amount of time ?","replyToPid":390878}
发表于 2020-7-27 21:20:49 来自手机 | 显示全部楼层
953162 发表于 2020-07-27 11:41:16 I don’t have to be an authority for a certain amount of time ?
","text":"no. just need to set yourself up with them. Ask for a carrier setup pack and you know all the info you need to send them before they let you accept a load.","replyToPid":390882}
发表于 2020-7-28 05:34:06 来自手机 | 显示全部楼层
","text":"Some Companies do require to have had your authority for a certain amount of time, some require to have more than one truck... ","replyToPid":390882}
发表于 2020-7-28 15:15:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"my dispatcher work's at home","replyToPid":0}
GMT+8, 2026-3-21 07:56 , Processed in 0.100419 second(s), 23 queries .
