查看: 73|回复: 0
2014 UTILITY 3000R
 楼主| 发表于 2020-7-26 08:11:04 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
VIN: 1UYVS2532EU774623
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=2cded30717388756de1&token=33f6a55a595577026a4a6b2b1aeefa64
suspensionV2: Hendrickson
tiresV2: Wide Base Single
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
categoryV2: Reefer Trailers
zipcodeV2: 65803
cityV2: Springfield
stateV2: MO
condV2: Used
makemodelV2: UTILITY 3000R
phonenoV2: 5623747861
priceV2: 24400
stocknoV2: 141347
latitudeV2: 37.19
longitudeV2: -93.28
modelyearV2: 2014
compartmentsV2:
includeForkliftV2: -
LucrativId: 3507056
LocationId: 2974840
{"text":"2014 UTILITY 3000R CARRIER 2500A With 12,xxx HOURS, Tire Inflation, Right Weigh Load Scale, Bendix TABS-6 ABS, Hendrickson HKANT 40K Air Ride/Slider System, Corrugated Side Panels, UTM Barrier Double Swing Rear Doors with Stainless Steel Diamond Pattern, Veristex Wall Liner, LED Lights and more.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 21:40 , Processed in 0.292488 second(s), 25 queries .
